Author Topic: Ambient Weather WS-900-IP (Wireless)  (Read 1443 times)
Offline JayTees
  • https://www.wunderground.com/personal-weather-station/dashboard?ID=KMOJACKS28
    • My Weather Station
« on: June 24, 2018, 10:23:44 AM »
Thought I would share my photos (should be attached). Not a perfect installation, but, about as good as I'm going to get at my house.
  • Main Unit pole mounted about 5' above roof ridge
    Outdoor Temperature/Hygrometer/Barometer unit mounted under eaves, on the North side of the house.
    Also indoor Temperature/Hygrometer/Barometer unit
Shared through Weather Underground https://www.wunderground.com/personal-weather-station/dashboard?ID=KMOJACKS28#history and monitored on ambientweather.net. Wunderground seems to be a little flaky sometimes, not reporting current data when I can see it on ambientweather.net.
When in danger, or in doubt,
Run in circles, scream and shout!
Re: Ambient Weather WS-900-IP (Wireless)
« Reply #1 on: August 19, 2018, 09:07:58 PM »
Looks good. Good height for roof mount. But since the roof mount sensor array does not have the temperature sensor you don't have to worry about roof radiation. But even if in the future you replaced it with a WS-2902A or some other fully integrated model with that height I think you are good.
