Author Topic: No internet connection **solved**  (Read 1571 times)
Offline DoctorKnow
« on: June 08, 2018, 02:13:18 PM »
I can upload to CWOP and PWS wx. Not Wunderground, AWEKAS or Wxcloud... Any ideas?
AN IP:  192.168.1.10WLAN IP:  --
 LAN Mask:  255.255.255.0WLAN Mask:  --
 Gateway:  192.168.1.1TX Traffic:  -- DNS:  192.168.1.1RX Traffic:  -- WAN IP:  No Internet AccessProvider:
System MessageError: Weather Underground:
Error: Weather Cloud:
Error: AWEKAS:
noWeather Underground:2018-06-08 14:12:46 Error: wget: unable to resolve host address 'rtupdate.wunderground.com'  (no more tries)
noWeather Cloud: 2018-06-08 14:12:06 Error: wget: unable to resolve host address 'api.weathercloud.net'  (no more tries)
noAWEKAS: 2018-06-08 14:11:45 Error: wget: unable to resolve host address 'data.awekas.at'  (no more tries)
noWeatherForYou: 2018-06-08 14:12:06 Success!
noCWOP: 2018-06-08 14:12:06 Success!
noTwitter Upload: 2018-06-08 14:11:43 Error: can not post tweet (no authentication)  (no more tries)
« Last Edit: June 15, 2018, 11:21:01 AM by docbee »
Re: No internet connection
« Reply #1 on: June 08, 2018, 05:57:31 PM »
Who knows?  Likely some server config/access issue - ask you ISP.  can you ping the sites that are  erroring out?
Offline docbee
  • Moderator
    • smartbedded
« Reply #2 on: June 09, 2018, 07:28:03 AM »
looks like DNS is not working fine. To get around this you can define network settings manually (not DHCP) and insert 8.8.8.8 as DNS, which usually works fine.
Offline DoctorKnow
« Reply #3 on: June 09, 2018, 11:18:53 AM »
OK, I'll work on it again when I get a chance. Thanks guys.
I may need a new main router... Not sure. I had to do a system restore on the PC. I think something came in that caused all this.
Offline DoctorKnow
« Reply #4 on: June 09, 2018, 01:45:28 PM »
Doc is a genius! I am up and running again. :D
