Author Topic: Davis VP2 Rain Gauge  (Read 1535 times)
Offline WxLover16
Re: Davis VP2 Rain Gauge
« Reply #25 on: May 29, 2018, 09:50:13 PM »
Well, yeah...the manual will always be more accurate.
Well, yeah...I'll always be a bit lazy.  Just get me in the ballpark and gimmie a beer...  :lol:
Seriously, though, I can't (don't know how) to automatically pull in manual readings into my website.  So getting as close as I can to an automated reading is very desirable for me.
The above paragraph sounds rather confusing even to me, and I wrote it.
Off-topic here but just wondering, I see your location is basically due south of Montgomery. Did you get into the eye-wall of Alberto?
Davis Wireless VP2 SHT31 24hr 24CFM FARS
    • Conditions @ CW2274
« Reply #26 on: May 29, 2018, 10:00:46 PM »
but in the end the manual will not under-report.
Not necessarily, splash out has been documented by Valentine WX (Randy) when using the Coco in downpours with it's "smallish" depth of cone.
Offline Intheswamp
    • Beeweather
« Reply #27 on: May 29, 2018, 10:28:16 PM »
You know, I was wondering about that.  It does seem rather shallow, but still seems to do better than the Davis.  :???:
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
Tried to lift one of vreihen's gold stars but wasn't smart enough to do it....<grin>
« Reply #28 on: May 29, 2018, 10:31:01 PM »
Ain't nothin' perfect...
« Reply #29 on: May 30, 2018, 12:12:06 AM »
Not because of lack of effort. :idea:  I've modified a couple tops to prevent splash out and even catch hail now.
« Reply #30 on: May 30, 2018, 12:55:09 AM »
For sure. Although not as convenient, one can always just remove the funnel and tube and take the catch and pour it into the tube for measurement later. Problem is, it's later. I like knowing now, at a glance, through the dry side of my window.
Offline Intheswamp
    • Beeweather
« Reply #31 on: May 30, 2018, 10:13:00 PM »
Yeah, it pretty much wiped it's feet on our front door mat.  Not a big event, though.  A lot of rain, some wind, but nothing as bad as some thunderstorms that come through from time to time...just longer period of rain and wind.  It was very unlike Opal that pretty well bullseyed us...that was one storm that I did get a bit nervous about.  Opened the back porch door and shined a spotlight out onto a 75' or so pecan tree only to see it's top bent over by the wind touching the ground...I closed the door and high-tailed it back to the interior hall.  But, when the first eye wall passed us and we were in the eye I went outside and it was as calm as could be (except for my daughters and wife yelling at me to get back inside! :lol:).  The big pecan tree and a cousin of it both had one side of their rootballs pooched up about a foot or so above ground level.  I went back inside, we passed through the other eyewall and the storm started up again.  Both pecan trees were on the ground the next morning, roof damage, a good bit of timber damage.  I don't want to see that again.
Davis VP2, v3.12
www.beeweather.com
Offline Intheswamp
    • Beeweather
« Reply #32 on: June 30, 2018, 10:17:29 AM »
I didn't want to leave everyone in suspense so here is an update. :lol:
I just punched the button on a Rainwise 111 gauge.  It'll probably be here the end of next week and hopefully I'll get it installed in a reasonable length of time (I tend to drag my feet sometimes :roll: ).
Has anybody added bird spikes to a Rainwise 111???  I'm sold on them after using the hour-glass, spike-ringed Davis buckets.
Any other modifications that would be good?
Ed
Davis VP2, v3.12
www.beeweather.com
Offline JCA433
« Reply #33 on: June 30, 2018, 11:44:22 AM »
The tipping bucket rain gauge part of my VP2 weather station also drastically measured less rainfall compared to the CoCoRaHS rain gauge by about 20 percent.  The recent adjustments I made seemed to have improved the performance to the point that both the VP2 rain gauge and the CoCoRaHS rain gauge are within 4 percent.  However it is too soon to be sure if the VP2 rain gauge will continue to perform well.  Here are the results over the past ten days.
CoCoRaHS gauge             VP2 rain gauge
0.01 inch                                  0
0.01 inch                                 0.01 inch
0.06 inch                                 0.06 inch
0.46 inch                                 0.48 inch
0.01 inch                                 0.01 inch
0.29 inch                                 0.33 inch
0.09 inch                                 0.09 inch
0.15 inch                                 0.15 inch
0.25 inch                                 0.26 inch
0.17 inch                                 0.18 inch
« Last Edit: June 30, 2018, 11:57:24 AM by JCA433 »
Offline JCA433
« Reply #34 on: June 30, 2018, 12:09:52 PM »
I still do not trust the VP2 rain gauge because the mounting pole movement during strong winds increases the error.  Somehow I must prevent the  mounting pole from moving if the rain fall measurement will ever be reliable.  However at least the rainfall measurements are closer.
I forgot to mention that I also replaced the temperature and humidity sensor because it did not for some reason measure humidity over 90 percent.    The new sensor is model 7346.070.  The humidity is often very high here in Miami Dade Florida and maybe this wears out the senor over time?
« Last Edit: June 30, 2018, 12:26:18 PM by JCA433 »
« Reply #35 on: June 30, 2018, 01:16:10 PM »
Good deal Ed. You will like the Rainwise. Also glad to see the Davis more accurate after calibration but like JCA433 mentioned the mounting will always be an issue and real test will come with bigger rainfall amounts.
My Texas electronics is main tipping bucket primarily because it has the heater. I trust the Rainwise just as much maybe more  because the TE seems to loose calibration with temperature changes. It works fine in summer but as temps fall calibration gets off while the Rainwise holds calibration down to freezing well.
Todays rain all gauges were the same TE top gauge Rainwise bottom and both Cocorahs, NWS 8" all came in at .63. This was result when heavy rain doesn't fall the tipping buckets keep up well.
Just so everyone knows I use a professional calibrator made by Novalynx and go with the recommended rainfall/rate they suggest on tipping bucket gauges.
Edit: They suggest the 4" per hr. rate which seems high but results speak for itself.
« Last Edit: June 30, 2018, 01:42:11 PM by ValentineWeather »
« Reply #36 on: June 30, 2018, 02:55:54 PM »
=D&gt; Get it level and solidly placed, it'll reward you with excellent accuracy for a tipper.
« Reply #37 on: June 30, 2018, 02:57:42 PM »
You're gonna love the SHT31. Don't forget the offset if needed.
Offline Intheswamp
    • Beeweather
« Reply #38 on: June 30, 2018, 10:22:02 PM »
Thanks for the feedback, everybody.  The VP2 ISS is mounted on a 4x4 post so I'm figuring on mounting the Rainwise gauge to the backside of the post.  Will figure out a shelf system for it that is stable.  I'm looking forward to it.  I also need to replace the temp/humidity sensor....got the SHT31 in a box here...somewhere. :roll:
Davis VP2, v3.12
www.beeweather.com
Offline DRoberts
« Reply #39 on: July 06, 2018, 01:52:32 PM »
Realizing that one measurement does not lead to an indisputable conclusion, I was a bit surprised when both my CoCoRaHS and VP 2 gauges agreed on .29" in a fast hard rain (duration 16minutes).
Usually the CoCoRaHS measures less than the tipping bucket.
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #40 on: July 06, 2018, 04:35:55 PM »
Interesting. The tipping bucket theory states that the bucket reading should be less.
Sent from my MHA-L29 using Tapatalk
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline Intheswamp
    • Beeweather
« Reply #41 on: July 06, 2018, 04:40:18 PM »
The Davis reading less is what I found when I set up the Cocorahs....and that's what prompted me to order the Rainwise bucket.
Btw, the bucket arrived yesterday....hopefully in the next week or so I'll figure out a mounting system for it...
Davis VP2, v3.12
www.beeweather.com
« Reply #42 on: July 06, 2018, 04:44:55 PM »
Are you going to hard wire it to the ISS?
Offline DRoberts
« Reply #43 on: July 06, 2018, 04:54:22 PM »
I will have to do a more complete comparison of the two.  My previous post was based on the few observations I have had the opportunity to make. It doesn't rain that often here, and I have had my station operational only since 27 May.
I don't think I have a siting problem with my CoCoRaHS, But I have been wondering about that ash tree.
Offline Intheswamp
    • Beeweather
« Reply #44 on: July 06, 2018, 05:04:21 PM »
Yeah, hardwired to the ISS and just have the Davis bucket for back-up (if ever needed) and for spider housing. :-)
Davis VP2, v3.12
www.beeweather.com
Offline Intheswamp
    • Beeweather
« Reply #45 on: July 06, 2018, 05:05:48 PM »
Keep an eye on it and let us know how it goes.  It seems, from what I've seen, that the usual result is as we mentioned...Davis records lower than the Cocorahs gauges does.
Davis VP2, v3.12
www.beeweather.com
« Reply #46 on: July 06, 2018, 05:17:57 PM »
You'll like it. I eventually removed the stock bucket and tipping mechanism, not necessary but I didn't see any reason to leave it there, just ma nature's junk collector.
Offline Old Tele man
  • Singing in the rain...
« Reply #47 on: July 06, 2018, 05:49:21 PM »
For everyone operating both CoCoRaHS and Davis tipping units, here's a post asking for your help/input:
http://www.wxforum.net/index.php?topic=34669.0
SYS: Davis VP2 Vue/WL-IP & Envoy8X/WL-USB;
DBX2 & DBX1 Precision Digital Barographs
CWOP: DW6988 - 2 miles NNE of Cortaro, AZ
WU - KAZTUCSO202, Countryside
