Author Topic: Anyone found a way to run the "Davis 'Live' Console script" on VWS?  (Read 985 times)
Offline BrianLehan
    • Grace C Lehan Memorial Weather Station
I like the Davis 'Live' Console script that is on the Silver Acorn site https://silveracorn.nz/weather/wxscripts.php for Weather Display and Cumulus. Anyone figured if the scripts can be edited or what source files might be needed to be created to run it from an VWS based system?
I'm slowly pushing my site over to a Saratoga based scripted one from the old VWS template, and while most of it is working on my testing server I have had some issues so its a slow roll out.
In researching my scripting issues I stumbled across the Davis live console package and now I am smitten with wanting to add it to my revised site. In case you haven't seen it, take a look. :shock: https://silveracorn.nz/weather/davconvp2CW.php
I thought maybe I could just abandon VWS and set up WD, but then I thought I might be able to run both and only use WD to feed the Davis Console? I'm kind of attached to VWS and WU at the moment
Yeah I have issues. Thanks  ](*,)
Brian
Davis Vantage Pro 2 plus
VWS 15x
Sarasota-Weather Template
Gr3 Radar
