Author Topic: Using VWS as stationless by reading CSV from WD  (Read 1913 times)
Offline PSJohn
    • DesertWeather.com
« on: May 16, 2018, 11:28:38 PM »
Can VWS be set to "stationless" and read a CSV file created by WeatherDisplay? If so does anyone know what format VWS expects?
I'm using Virtual VP now, and I'm constantly dealing with disconnects from VWS. I wish to finally decommission it!
thanks in advance.
John Slama
Palm Springs, California
Davis Vantage Pro 2, FARS
Offline swise123
    • Current Nashville Weather
Re: Using VWS as stationless by reading CSV from WD
« Reply #1 on: June 15, 2018, 11:58:34 AM »
Was curious as to if you tried this and if it worked?
Shane
www.nashvilleweather.net
Offline PSJohn
    • DesertWeather.com
« Reply #2 on: June 15, 2018, 02:20:46 PM »
Yes! I have it working! Its been flawless so far 3 days in! I still haven't had rain to test those perimeters. I had to reset VWS total rain after the setting change to station less.
I went to Brian (WD Developer) over at the Weather Display forums and he did help me. Here is the link to that conversation you can see....https://www.weather-watch.com/smf/index.php/topic,66693.0.html
I had VWS, WD, and Cumulus working with VirtualVP for at least the last 10 years not knowing what software I would end up using. Then with VirtualVP's development demise I have had connection errors for years I had to deal with. Now I'm running only WD, for 95% of my website, and VWS for a few graphics and to use with ImageSalsa. No VirtualVP!
John Slama
Offline swise123
« Reply #3 on: June 15, 2018, 02:50:58 PM »
Thanks for the info...I am looking to possibly move away from VWS since it's not being updated anymore and was looking at WD.
Offline AF6GL
    • Jeffries Ranch Weather Center
« Reply #4 on: August 22, 2018, 03:22:48 PM »
I am trying to use VWS stainless with WD. VWS won't save my settings in the stainless mode. Any suggestions?
Offline longmire
  • VWS 15 p03 GRL3_2 WF L2K W7-Ult-64-SP1 TWI WR-25
« Reply #5 on: November 12, 2018, 01:45:02 PM »
So - I have sort of the opposite question - is it possible to leave VWS collecting the data and have WD read in "stationless" mode from vws? I'd like to have a way to upload the data to the MySQL database when my aging install of vwsql says "NO!" for the last time.
Online galfert
« Reply #6 on: November 12, 2018, 02:49:27 PM »
Why not run VirtualVP and then run both VWS and Weather-Display?
http://www.softwx.com/weather/virtualvp.html
Offline longmire
« Reply #7 on: November 12, 2018, 09:49:16 PM »
Because my weather station is a Texas Weather wr-25 connected via rs-232 and virtual vp won't work if you don't have a davis station.
