Author Topic: Metar server down ?  (Read 5030 times)
Offline wvdkuil
  • Wim van der kuil
Metar server down ?
« on: May 07, 2018, 02:15:15 PM »
More then half the requests for a METAR from http://tgftp.nws.noaa.gov result in errors since yesterday.
Example:
USA:   http://tgftp.nws.noaa.gov/data/observations/metar/stations/KMMU.TXT
Europe: http://tgftp.nws.noaa.gov/data/observations/metar/stations/EBBR.TXT
Errors such as Connection reset by peer or a timeout, even after 10 seconds.
Any ideas?
Is there another source for raw METAR data?
The METAR is used to get current-weather-conditions (CCN) for weather-sites using a weather-program which does not supply CCN
P.S. Leuven-Template users can switch to Yahoo to get CCN by changing the appropriate setting.
Support for the HWS-WD34-template for WD a.o.  http://wd34.weather-template.com/
Script sponsors https://support.leuven-template.eu/userlistScripts.php
Template sponsors https://support.leuven-template.eu/userlist.php
Re: Metar server down ?
« Reply #1 on: May 07, 2018, 02:58:03 PM »
Same here, I've been seeing it often hangs site for about 10 seconds when it occurs.
« Reply #2 on: May 07, 2018, 03:43:37 PM »
Went ahead and comment out // conditions metar for now.  It's been bad all day. Really last month or more. :sad:
I'm surprised others haven't noticed , if they have not much is being mentioned or maybe it's just my region again.  I went as far as ordering a solar sensor trying to get away from METAR altogether.
« Last Edit: May 07, 2018, 03:47:17 PM by ValentineWeather »
« Reply #3 on: May 07, 2018, 07:55:01 PM »
Looks like the tgftp.nws.noaa.gov server is back running.. maybe they are moving stuff around to new servers ?!?.. didn't see any pre-outage notices on the NWS mailing list.
« Reply #4 on: June 28, 2018, 01:21:37 PM »
Looks like metar server is down again.
Offline wvdkuil
  • Wim van der kuil
« Reply #5 on: June 28, 2018, 01:22:48 PM »
Yes, it is down.
No response from the server at all.
Offline wvdkuil
  • Wim van der kuil
« Reply #6 on: June 28, 2018, 01:45:49 PM »
And up again,
« Reply #7 on: June 28, 2018, 01:46:24 PM »
Thanks I just hashed out conditions icon to prevent site hang.
Wish there was a work around for rain override to work with metar hashed out also. I have cameras and only have enabled so  local station rain conditions will show on dashboard.
I tried it with metar hashed out but didn't work. If this would work I wouldn't use airport metar at all.
« Reply #8 on: June 28, 2018, 01:47:46 PM »
Its in a up and down phase again, I noticed it down early this morning and came back up.
Offline so_whats_happening
« Reply #9 on: July 24, 2018, 09:33:47 PM »
Not sure if you guys use this or not aviationweather.gov is pretty decent it crashes a few times here and there but overall pretty decent can get most metar stations auto or manned stations. I think you can also get most countries.
Offline wvdkuil
  • Wim van der kuil
« Reply #10 on: July 25, 2018, 03:32:46 AM »
Thanks  :grin: for your post, I totally forgot this aviationweather.gov site, I used it in the past.
Disadvanteges?:
I wonder if aviationweather gets its data from another source, if they load their data also from   tgftp.nws.noaa.gov  they are down at the same time .
To construct the "Current Conditions" for a weather-station, the scripts use a CURL or a  filegetcontents to load the METAR .  Although good scripts cache the result and reuse it for at least 15 minutes, the METAR is relatively frequently loaded.
Using aviationweather.gov adds considerable server bandwidth  as for more data is received then the METAR-data itself.
This link: https://aviationweather.gov/metar/data?ids=EBBR&format=raw&date=0&hours=0
HTML size = 19kB for  this data set "EBBR 250650Z 03005KT 360V060 CAVOK 23/16 Q1016 NOSIG" .
Also we should "scrape" the html to get at the METAR  => extra server time + changes in the scripts when the aviationweather site changes.
Advantages:
This aviationweather site also supplies the data in xml. In a previous release I used their DATA in my scripts that way as I do not like scraping  HTML. Probably it is allowed to load the data as it is a USA .gov website. This is the xml one should use
https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&hoursBeforeNow=3&mostRecent=true&stationString=EBBR
To do:
  • Check the consistency of the response times.
  • Check if they are down when tgftp.nws.noaa.gov is down
Offline wvdkuil
  • Wim van der kuil
« Reply #11 on: February 04, 2019, 11:15:42 AM »
https://tgftp.nws.noaa.gov/ is down on Feb, 4  since 16:00 UTC
The alternative is up: https://aviationweather.gov/  but it will take some time to check if they have recent data, the ones I checked were all from before 16:00 UTC.
Another alternative, which needs a free API-key,  is still up: https://api.checkwx.com/
Again, I have to check if they have METAR's with a timestamp after 16:00 UTC
« Last Edit: February 04, 2019, 11:24:16 AM by wvdkuil »
« Reply #12 on: February 04, 2019, 11:24:58 AM »
The alternative is up: https://aviationweather.gov/  but it will take some time to check if they have recent data, the ones i checked were all from before 16:00 UTC.
I am getting "unable to load KPZQ data RC=302 Object Moved" where the icon normally is on my page. The METAR reports are all showing "Not Current" and the same error message as the icon.
Offline wvdkuil
  • Wim van der kuil
« Reply #13 on: February 04, 2019, 11:36:06 AM »
The connection error reported is  SSL_ERROR_UNRECOGNIZED_NAME_ALERT
At 16:35 the site was up again.
I could verify that https://aviationweather.gov/  returned data with a timestamp after 16:00 UTC .
They are not getting their data from  https://tgftp.nws.noaa.gov/
« Last Edit: February 04, 2019, 11:39:17 AM by wvdkuil »
« Reply #14 on: February 04, 2019, 11:38:08 AM »
This text page just came back:
http://tgftp.nws.noaa.gov/data/observations/metar/decoded/KPZQ.TXT
It was missing earlier.
« Reply #15 on: February 04, 2019, 05:33:42 PM »
The text METAR data is the only thing that started to work again. The other METAR functions are still returning the "302" error.
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #16 on: February 04, 2019, 06:11:28 PM »
Metar data is now working here in UK ok https://www.conligwx.org/wxmetar.php
« Reply #17 on: February 04, 2019, 06:35:43 PM »
I was getting the same thing unable to load. Downloaded the latest 'get-metar-conditions-inc.php' and cleared right up.
You need the 2018 version they updated. 2017 didn't work.
« Reply #18 on: February 04, 2019, 07:30:35 PM »
Fixed with the update from Saratoga-Weather.org. The get-metar-conditions-inc.php file seems to have resolved it. Thanks for the "heads up" Randy.
    Updated: 2018-11-30 06:53
    Version 'get-metar-conditions-inc.php - Version 1.17 - 30-Nov-2018'
    Recommend: Replace current copy with updated copy.
« Reply #19 on: February 04, 2019, 10:19:19 PM »
Welcome,
Offline satcop
    • Clifton Virginia Weather
« Reply #20 on: February 05, 2019, 07:38:18 PM »
Thanks folks I was having the same problem\, all the metar access programs stopped working last night.  Looked here and found your solution and as advertised the  latest get-metar-conditions-inc.php file fixed it.  Thank you. :grin:
Clifton, Virginia Weather
« Reply #21 on: February 07, 2019, 05:04:17 PM »
The METAR is back to not loading again. What is NWS doing???
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #22 on: February 07, 2019, 05:17:04 PM »
yep noticed here too. site must be down.
« Reply #23 on: February 07, 2019, 05:49:58 PM »
It appeared to automagically fix itself....
Offline satcop
« Reply #24 on: February 07, 2019, 06:15:58 PM »
Interesting that it came back up for you folks, can't get to the site from here now.  I wonder if they changed a routing and the table hasn't got through the system yet.  Will see if it comes up here.
Update:  Well it didn't work all night and early this morning, but a little after 7:30 am this morning local time the links started working again.  Someone must have kicked a server somewhere after the morning coffee.
« Last Edit: February 08, 2019, 07:59:24 AM by satcop »
