Author Topic: advanced question...  (Read 965 times)
Offline BristolRILiveWx
    • The Rudman Radar
« on: May 05, 2018, 04:51:12 PM »
I have a wireless davis vantage pro2 plus connected to a windows laptop running weather display and wxsim...I run my own network if you will and have a Mac mini server running some services on my network for all my devices, etc...
my question is, can meteotemplate run on a local web server and function the way it does on a remote server? what would one need to do to make this happen? I am pretty technical, so I feel it should be able to.
I know I can have weather display upload to my local server. I do have a web address that already points to my server externally, and run my own local firewall, dns and web server. anyways, like I said, I feel this is possible but not exactly sure what I would need to make it happen.
Davis Vantage Pro 2 Plus, Windows 7 SP1, WD 10.37S44
Offline yamiacaveman
    • Penn Lake Weather
Re: advanced question...
« Reply #1 on: May 06, 2018, 09:07:38 AM »
The best one to ask that question is jachymcz@gmail.com or try the website http://www.meteotemplate.com/web/index.php
I know he visits here sometimes, but i understand he has taken on a new job title and for the moment is in to that pretty heavy.
He usually responds very quickly and he is the developer.
Hope that helps
Offline bchwdlks
« Reply #2 on: May 06, 2018, 11:16:37 AM »
Yes, it will function while running locally. I am using a RapsberryPi with Apache. It is running 2 different meteotemplate releases. Create a meteotemplate directory where your web server software can access it. Then install your meteotemplate in that directory. On the RPi Apache by default looks in /var/www/html. One of my releases is in /var/www/html/meteo and the other is /var/www/html/meteo13.
They are accessed on the local network by http://"local server ip"/meteo  and http://"local server ip"/meteo13. Neither is accessible outside my local network.
