Author Topic: Plug and play -ish?  (Read 1103 times)
Offline jumbo0
Plug and play -ish?
« on: April 22, 2018, 05:44:09 PM »
Hi!
When I was still living with my parents I had a Blitzortung system for detecting lightning, but since it required a PC to be turned on at all times I abandoned the system when I moved in my new house. But now I'd like to have a new station that doesn't need a PC contineously running, but since I'm not so good in electronics I was wondering if there was somebody that was selling a system (system blue preferrably) as much as possible plug and play?
Thanks in advance!
Offline Cutty Sark Sailor
Re: Plug and play -ish?
« Reply #1 on: April 23, 2018, 05:52:07 PM »
Blitzortung RED and BLUE systems only require an internet connection.... The GUI, that is settings, etc, is accessed from a PC or other device through either WAN or LAN, but is NOT necessary at all for the system to function once optimized, you'd access for setup, changes, local observation of operation, etc...
This is not your father's Blitzortung....  :D
There are incredible difference between what you had,... I assume a Green???
PM me.
Mike
