So what is the purpose to all of this whirlpool theory?
About tidal force:
For reference: "Tidal forces in nature - the statement that the center of the Earth is less attracted by the Moon than the surface of the Earth due to its remoteness." The degree of heterogeneity of the gravitational field of the Earth depends on the distance from the Center of the Earth to the Earth's surface. And the larger the radius of the planet, the greater the heterogeneity of the gravitational field.
If tidal forces existed, then the pressure of water and air would certainly react to this, especially during the parade of the planets.
Darwin and Laplace scattered with their research the belief that the Moon influences the barometer with its attraction.
http://www.e-reading.mobi/chapter.php/87995/21/Voroncov-Vel%27yaminov_-_Laplas.htmlDoes the gravity of the moon create two atmospheric humps, at what speed does the air tidal hump move from east to west? Like cyclones and anticyclones manage to move from west to east, at a speed of 50 km / h, rubbing the surface of the continents while the lunar air tidal wave, moving from east to west at a speed of 1600km / h.
Do two air tides form in the mountain cabin every day, does the speed and direction of the wind change, because moving the atmosphere is much easier than water?
Also, there is no convincing evidence and facts, deformation of the Earth's continents under the action of tidal forces.
Although the deformation of the continents can be easily checked by aiming with a telescope at the top of a mountain or at a geostationary satellite.
Quite often, airplanes move along the equator toward the moon and against the moon when the sun is at the top and the tidal force would be noticed by pilots on fuel consumption and flight time ..
It is believed that the maximum ebb and flow are in the new moon due to the fact that the Moon and the Sun act by gravity on the Earth in one direction. But in reality, the Moon revolves around the Earth, then it speeds up the slowing down of the Earth’s orbital speed, so that on a new moon, the Earth’s orbital speed is maximum, and in a full moon, the minimum, as a result, the amplitude of the tidal wave changes, which clearly shows and reacts with the globe .
The gravity of the moon has no effect on the ebb and flow.
The role of the moon is indirect, creating an uneven orbital velocity of the Earth ..
Once a year, the Earth approaches the Sun as close as possible to the Sun (perihelion), and the orbital speed of the Earth increases as much as possible and as a result, the height of tides and ebbs increases, and the gravitational and centrifugal forces also increase in perihelion, but they are mutually balanced.
The orbital velocity of the Earth at perihelion is 30.27 km / s and at aphelion 29.27 km / s.
It is believed that the tidal forces stopped the rotation of the moon, and now it rotates synchronously. But there are more than 300 known satellites and why they all stopped at the same time and where did the force that rotated the satellites go ...
If the "Lunar tidal current" existed, it would really quickly stop the rotation of the Earth, since enormous energy would be expended on the ebb and flow. And the energy of the western transfer of the atmosphere, which rotates the Earth, is not so high as to rotate and knead the Earth, like a concrete mixer ..
Tidal forces today are successfully used as a plug from many secrets of nature.
But in fact, they exist only theoretically, and in practice, not a single gravimetric device recorded them.
The acceleration of gravity at the equator is less than at the poles: at the equator is 978 Gal, and at the poles - 983 Gal.
There is no data on the fluctuation of tidal forces; if there were fluctuations, there would be data.
Why in the phase of the new moon, the pendulum clock does not go slowly ..
A geostationary satellite of the Earth speaking as part of the Earth is in weightlessness, at a distance of 35 thousand km. from the Earth, and for some reason, is not subject to tidal influence of the Moon, despite the fact that the "tidal force" in the Earth-satellite system is 5 times more than on Earth.
https://ru.m.wikipedia.org/wiki/Geostationary_orbitIf the oceans and continents that are under the satellite, the moon raises, "at 0.5 m, then the satellite which is in weightlessness, the moon should easily attract to itself, especially during the new moon, and the parade of planets.
And it is not necessary to forget that the oceans and continents are attracted by the Earth, and the satellite is in weightlessness ..
What theory or experiment proves that the gravity of the planets is infinite?
The formula F = Gm1m2 / r2 does not prove that gravity is infinite.
The law of the world says that the force of gravitational attraction between two material points is proportional to both masses and inversely proportional to the square of the distance between them.
https://en.m.wikipedia.org/wiki/Newton%27s_law_of_universal_gravitationAnd not a word about infinite gravity.
If the gravity of the Earth reached the Sun, then the Earth would have burned down long ago.
What will the formula of gravitational force look like if the gravity of the earth reaches no more than 50,000,000 km, and the moon 100,000 km?
