Author Topic: Pi 3 B+  (Read 1446 times)
Offline kd7eir
Pi 3 B+
« on: March 20, 2018, 12:50:13 PM »
Is Weewx compatible with the new Pi 3 B+?
Re: Pi 3 B+
« Reply #1 on: March 20, 2018, 04:43:54 PM »
Why wouldn't it be?
Offline kd7eir
Re: Pi 3 B+
« Reply #2 on: March 20, 2018, 04:47:55 PM »
I came across some reports that software needed to be updated for the Pi 3 B+
Perhaps they were confusing that with needing to update Raspbian for the 3 B+
Online nincehelser
    • nincehelser.com
Re: Pi 3 B+
« Reply #3 on: March 20, 2018, 05:10:42 PM »
I'd also expect weewx to be fine.
I did get my Pi 3B+ today.  I'll see if I can try a quick load of weewx tonight to see how it goes.
Online nincehelser
    • nincehelser.com
Re: Pi 3 B+
« Reply #4 on: March 20, 2018, 06:24:13 PM »
Everything looks OK with weewx on the Pi 3 B+.
I did a fresh install of Raspbian Stretch from a full NOOBS setup, then loaded weewx using the instructions here: http://weewx.com/docs/debian.htm
Using the weewx defaults and running the simulator, everything seems to come up fine.
The only problems I ran into weren't weewx related.
The power supply I've been using wimped out on me, and the Stretch installation would fail at about 17%.  I could tell I was having power issues because of the "lightning bolt" that would appear from time to time on the desktop.  Using a beefier power supply fixed that problem.
Setting up the WiFi took a little longer than usual as you now have to set the country code for WiFi in raspi-conf.
Otherwise, setup of the Pi and weewx was typical.
Offline kd7eir
Re: Pi 3 B+
« Reply #5 on: March 20, 2018, 06:35:29 PM »
Thank you for testing that for me! I'll get to work on mine tonight.
Offline kd7eir
Re: Pi 3 B+
« Reply #6 on: March 20, 2018, 10:16:39 PM »
I got the RTC setup and weewx installed - all seems to be working fine. Since I'm feeding meteotemplate it makes no difference, but I did notice that there is no /var/www folder.
