Author Topic: Retrieve Data from Atlas  (Read 2067 times)
Offline gnuloco
« on: March 20, 2018, 11:31:15 AM »
Hello!
Noob here, looking to somehow get the data from my Atlas setup? Looking to use the data (realtime as possible) for a local intranet website.  I do realize that there is a CSV file on the SD card, but is there any other method for collecting this data?
Thank you in advance,
Offline alanb
Re: Retrieve Data from Atlas
« Reply #1 on: March 20, 2018, 01:21:31 PM »
You must be a beta tester as the Atlas doesn't seem to be for sale yet. Don't you get some kind of preferential tech support from Acurite as a beta tester?
Alan
Offline gnuloco
« Reply #2 on: March 20, 2018, 01:24:08 PM »
I signed an NDA and installed to specifications. Working well.
I will have to call them I suppose. Will report back if I figure anything out.
Online nincehelser
    • nincehelser.com
« Reply #3 on: March 20, 2018, 02:47:15 PM »
Hello!
At the moment the best you can do is sniff the data enroute to wunderground.  The wunderground data from the Atlas is unencrypted and sent rapid fire.
Another option would be to use RTL_433 to retrieve data off-the-air, but I'm not aware of anyone who has decoded the data yet.
Offline waiukuweather
« Reply #4 on: March 20, 2018, 02:52:05 PM »
this is your data
it is not good that its such a closed system like it is
Online nincehelser
    • nincehelser.com
« Reply #5 on: March 20, 2018, 03:02:18 PM »
this is your data
There are two "official" ways to get to your data... from the myAcurite website and from the SD card.
There's nothing to preclude another method of access being added in the future.
« Reply #6 on: March 20, 2018, 04:39:54 PM »
SD card?  Hmmm.... could you use one of those Wifi SD cards that they have form cameras??
Online nincehelser
    • nincehelser.com
« Reply #7 on: March 20, 2018, 04:52:18 PM »
Maybe.  I used to have an Eye-Fi SD card, but unfortunately I haven't been able to find it.
One "gotcha", though, is that the 10-second logged data is first held in an internal buffer, then the buffer is dumped to the SD card every 20 minutes, so it wouldn't be exactly "real-time".
« Reply #8 on: March 20, 2018, 09:21:06 PM »
but does the myacurite web site allow you to actually get YOUR data for your own use/logging/analysis ,etc?
Online nincehelser
    • nincehelser.com
« Reply #9 on: March 20, 2018, 09:50:33 PM »
What other data would they send you?  It's provided as a CSV file.
« Reply #10 on: March 20, 2018, 10:46:42 PM »
so you can download the data as a CSV file?
can that be auto?
waiting for the next drip feed of info
Online nincehelser
    • nincehelser.com
« Reply #11 on: March 20, 2018, 10:50:58 PM »
can that be auto?
Yes, it's a CSV file.
Currently there is no way to automate it on myAcurite's end.  You have to hit the download button and specify the time period you are interested in.  Then a few minutes later they send you an email with a link that downloads the file.
Online BeaverMeadow
« Reply #12 on: March 20, 2018, 10:51:19 PM »
You can download 30 days max so you must do this every month if you want the data for personal use.
« Reply #13 on: March 20, 2018, 11:09:31 PM »
personally I think its terrible how Acuite locks up YOUR data like this
I would be looking at other stations
not sure how anyone can defend how this works
Online nincehelser
    • nincehelser.com
« Reply #14 on: March 20, 2018, 11:18:35 PM »
What exactly are you talking about?
You can get your data in two different ways.  How is it "locked up"?
« Reply #15 on: March 20, 2018, 11:28:54 PM »
so you are defending this?
that the only way you can get YOUR data is by manually clicking to get a CSV file?
that is very restrictive
not sure how you can defend that
Online nincehelser
    • nincehelser.com
« Reply #16 on: March 20, 2018, 11:36:10 PM »
Who said that is the "only way" to get your data?  Remember the SD card mentioned earlier?
And I also said the current methods don't preclude other methods being added in the future.
Your data isn't "locked up".
Online BeaverMeadow
« Reply #17 on: March 21, 2018, 12:31:53 AM »
Hello!
Would it be a good idea for Acurite to give their customers the key to decode this data or are there valid reasons for them to keep it proprietary, and how do other companies like Davis and Ambient handle the data being transmitted from their weather stations?
« Reply #18 on: March 21, 2018, 12:59:08 AM »
since they have a powered hub, why do they not make the real time data available from that (e.g UDP broadcasts)
its YOUR data
it should be made easily available for you to use (i.e having that flexibility/option)
« Reply #19 on: March 21, 2018, 05:13:23 PM »
Unless Chaney decides to use some stupid strong encryption that will likely mess their system up, it is only a matter of time before the data stream is decoded.  Information yearns to be free!
Offline kd7eir
« Reply #20 on: March 21, 2018, 05:43:56 PM »
If you want the real time data stream it IS locked up. Refusing to let you access YOUR weather data stream in real time for use in any way that YOU see fit is draconian.
Offline kd7eir
« Reply #21 on: March 21, 2018, 06:07:15 PM »
"There have been some technical changes that will make network interception of the data more difficult, if not impossible.  Data is encrypted going to myAcurite.  Data to wunderground is currently not.  That could always change, though."
Proves to me that the end game for AcuRite is to FORCE people to PAY for access to My AcuRite to get real time access to YOUR data unless you are sitting at home in front of the screen. There is simply no excuse for this behavior by AcuRite, and stating that "It might change in the future" is simply AcuRite fanaticism. It DID change, to the ENCRYPTION that you mentioned. Since they went to the expense to encrypt the data, there is no chance that they will simply decide to throw that away - that is their golden ticket to fleece the consumer.
« Last Edit: March 21, 2018, 06:48:24 PM by kd7eir »
Offline vreihen
  • El Niņo chaser
  • K2BIG
« Reply #22 on: March 21, 2018, 06:50:55 PM »
They are definitely one-upping Netatmo, the poster child for un-tappable data streams with consumer-grade sampling intervals.....
Online nincehelser
    • nincehelser.com
« Reply #23 on: March 21, 2018, 07:13:33 PM »
Proves to me that the end game for AcuRite is to FORCE people to PAY for access to My AcuRite to get real time access to YOUR data unless you are sitting at home in front of the screen. There is simply no excuse for this behavior by AcuRite, and spouting off that "It might change in the future" is simply AcuRite fanboisism. It DID change, to the ENCRYPTION that you mentioned. Since they went to the expense to encrypt the data, there is no chance that they will simply decide to throw that away - that is their golden ticket to fleece the consumer.
I mentioned that wunderground data is currently unencrypted but that could eventually change.  How you can interpret that as "AcuRite fanboisism" (sic) is beyond me.
In any case, I'm just describing how things were during the Atlas beta test.  It was not the final product, and it will likely continue to evolve after the initial release.
No one is going to be holding your data "hostage".
Online nincehelser
    • nincehelser.com
« Reply #24 on: March 21, 2018, 07:17:46 PM »
But isn't encryption the road that everyone seems to be taking nowadays?  Continued gleaning of data from the network just doesn't seem like it's going to be practical in the future as everyone is demanding "privacy".
