Author Topic: Davis Vantage Pro2 - Super Capacitor Replacement - DIY  (Read 3790 times)
Offline nonnih
« on: March 02, 2018, 05:55:43 PM »
Hi all,
After 10 years of flawless service, my ISS stopped sending signal, and every time i replaced the battery it was exhausted within days.
As i am living in Iceland, we get not much sun from august to march and therefor i have had to replace the CR123 battery twice a year... until now maybe.
My super capacitor died and when i start working on replacing the capacitor i read on some articles that the standard capacitor is 2.7 v 10F, and it is possible to put an 50F capacitor, and more. As i have a European model, i can have 2 capacitors.  So i ordered 2x 2.7 50F capacitors and began to upgrade. It was an quite easy job, just a little bit soldering and my weather-station has working very nice after the upgrade.
I have here attached photos from my ISS, with the blown capacitor and the steps until it was ready.
Hope this will help out others in upgrading their ISS and fixing them.
Here is my ISS
After i remove the cover
Here is the blown Super Capacitor
Cleaning the hole for new capacitors, and opening new hole
New capacitors in place and ready for soldering
And this is how ISS with 2x 50F capacitors looks like.
Re: Davis Vantage Pro2 - Super Capacitor Replacement - DIY
« Reply #1 on: March 02, 2018, 06:36:54 PM »
Great pictures!  thanks.  There was a thread about multiple supercaps before so I will be curious to know how yours works out.  And I notice you did not hot  glue them or anything?
Offline W3DRM
    • Carson Valley Weather
« Reply #2 on: March 02, 2018, 10:57:38 PM »
Yes, great job! However, I hope you used some needle-nose pliers to hold the capacitor end of the wires so they were not stressed while bending the leads to fit the ISS board. Most capacitor failures occur from not stabilizing the leads on the capacitor end before bending them. Not doing this results in micro fractures at the capacitor end which will eventually fail. That is one of the reasons for securing the capacitor with hot glue or some other means of preventing the cap from moving around.
Davis Wireless VP2, WD 10.37s85,
--- RIPE Atlas Probe - 32849
Offline GeoAir.pt
« Reply #3 on: May 04, 2018, 11:24:36 AM »
Sorry to hijack this topic.
Would this be a suitable replacement https://www.tme.eu/gb/details/ds5u506m18040bb/supercapacitors/samwha/ ?
Thank you
Offline doubleohwhatever
« Reply #4 on: May 04, 2018, 01:57:27 PM »
Is there a reason two capacitors are not installed at the factory?
Offline Old Tele man
  • Singing in the rain...
« Reply #5 on: May 04, 2018, 04:01:52 PM »
Not really necessary in lower latitudes where daylight hours are both brighter and longer.
Offline johnd
« Reply #6 on: May 04, 2018, 04:17:01 PM »
And not at higher latitudes either I think - in the winter half of the year (ie when you might need extra charge in the supercap) there's not enough sunlight to charge one supercap, let alone two.
Littleport, Ely, Cambs UK
« Reply #7 on: May 04, 2018, 08:26:58 PM »
That makes sense.
« Reply #8 on: May 05, 2018, 08:27:02 AM »
Perhaps when the boards were initially designed, the available capacitance range wasn't as high as it is now. In general, cap technology trends to more µF (or F in this case), for the same package. For cost purposes, they probably found that they could get the same capacitance in a single package, eliminating the need for two.
Offline archae86
    • LynxStoll weather
« Reply #9 on: May 09, 2018, 08:22:09 AM »
As user reports here suggest that the super capacitor is one of the highest failure rate items in the system, I think not installing two where one is sufficient lowers costs and raises reliability.
Offline johnd
« Reply #10 on: May 09, 2018, 08:53:41 AM »
Doesn't it double the failure rate and so lower reliability?
Offline SnowHiker
« Reply #11 on: May 10, 2018, 03:47:54 AM »
No.
Offline johnd
« Reply #12 on: May 10, 2018, 04:08:13 AM »
No.
Well, if they're mounted in parallel (which I'm guessing they are) and a low resistance fault develops in either then you have a a problem. Hence reliability is lower.
Offline SnowHiker
« Reply #13 on: May 10, 2018, 04:17:16 AM »
No.
That's why he's saying it's more reliable to not use two instead of one.
Offline johnd
« Reply #14 on: May 10, 2018, 04:25:33 AM »
Ah, maybe I misread/misinterpreted the (sort of) double negative.  :? Apologies! So we all agree I think?
Offline SnowHiker
« Reply #15 on: May 10, 2018, 04:40:00 AM »
No apologies aren't not necessary, on my part anyway.
Online WheatonRon
    • WUnderground
« Reply #16 on: May 11, 2018, 03:06:04 PM »
Interesting topic. One of my wishes for enhancements in the next version of a VP2 (maybe a VP3), is an easy, replaceable super cap—plug in maybe? Oh well, Davis doesn’t seem interested, and decent competition doesn’t appear imminent. Maybe if iPhone sales dwindle Apple will start making PWS!
« Reply #17 on: May 11, 2018, 05:02:11 PM »
Here's a thought:  rechargeable batteries.  Who needs an SC?
Offline WiFiLogger
« Reply #18 on: May 11, 2018, 05:55:30 PM »
Useless in low temperature.
Offline dalecoy
    • Lee's Summit, MO
« Reply #19 on: May 11, 2018, 08:22:26 PM »
And the SuperCapacitor is, in effect, a rechargeable battery - that works just fine in low temperatures, etc.
« Reply #20 on: May 11, 2018, 08:25:30 PM »
Tell that to my inReach sat phone; my Garmin GPS, my GoPros, my Suunto watch (all of which I use to -35C in the mountains for tens of hours at a stretch) ...  Rechargables are pretty decent these days.  At least the right ones are.
« Reply #21 on: May 11, 2018, 08:26:38 PM »
When it works.  Until it doesn't then you have to resolder, taking care about leads etc. after you pull the thing apart. The Davis implementation is craptastic.
Offline dalecoy
    • Lee's Summit, MO
« Reply #22 on: May 11, 2018, 09:34:44 PM »
What would your design for reliable solar power be?
Online WheatonRon
    • WUnderground
« Reply #23 on: May 11, 2018, 09:35:50 PM »
Natural gas? Sorry, I couldn’t resist.
Offline johnd
« Reply #24 on: May 12, 2018, 03:40:29 AM »
See Davis EM.
