Author Topic: Spring/Summer '18  (Read 16421 times)
Re: Spring/Summer '18
« Reply #300 on: July 08, 2018, 10:51:08 PM »
Hey Earles, get any rain up there?? Maybe a clap or two of thunder?? :lol:
Offline WeatherHost
« Reply #301 on: July 09, 2018, 07:03:04 PM »
The white spots and streaks are heavy rain.  Pounding, driving rain I can hear inside the house hitting the metal roof and windows.  You can see what else is hitting the grass, trees and wet driveway.
Summer in the country I guess.
Banners, tags, widgets, etc. are why I have Signatures turned off.
Offline ValentineWeather
    • LiVE WEATHER
« Reply #302 on: July 10, 2018, 12:51:18 AM »
Phoenix tonight.
Randy
« Reply #303 on: July 10, 2018, 01:37:50 AM »
I'm soooo glad that we give that to them every summer instead of the other way around. :evil:
« Reply #304 on: July 12, 2018, 01:28:35 AM »
Map shows total days of highs above 100 in Oklahoma, which is confined to most of the western half of Oklahoma.   Far southwest Oklahoma easily has the hottest summers.  Some of the worst drought in the state is there.
Oklahoma City hasn't gotten to over a 100 yet, and 10 day forecast has no 100s in it.  The same with Tulsa.  This summer's weather hasn't been noteworthy of much of anything unusual.
Also the 2nd home page using modified AltDashboard 6.95 at http://stillwaterweather.com/wx/2ndhome.php
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #305 on: July 12, 2018, 02:28:26 AM »
The forecast from the Scripps station here does show 100 and 101 for Sunday and Monday. NWS shows 96/97 for those days. The humidity is back however and we have a heat advisory again tomorrow. Who knows.
As long as it's not like 2011 all over. That summer was brutal.
Sent from my MHA-L29 using Tapatalk
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline WeatherHost
« Reply #306 on: July 12, 2018, 11:37:56 AM »
Seems to be something afoot that will yield a significant cooldown after the 17th or 18th.  Two week forecast (which I know is Voodoo) has been consistent over the last couple of days showing mid 60s/low 80s from the 18th through the 26th.
If it happens, I'll welcome it.
« Reply #307 on: July 18, 2018, 03:58:58 AM »
Massive 100 plus HEATWAVE in all of Oklahoma coming Friday.  We'll see if the TV weatherman's  hype pans out.
« Last Edit: July 18, 2018, 04:10:04 AM by Bunty »
Offline DRoberts
« Reply #308 on: July 19, 2018, 01:11:21 PM »
Davis just took its first 75 mph wind this morning in a surprise 20% chance severe t-storm.
Also, the Davis rain gauge measured .51" in 30 min, while my CoCoRaHS measured .48" in the same period.
« Reply #309 on: July 19, 2018, 05:45:47 PM »
Dangerously high heat index in Stillwater with 120 during Thursday afternoon.  Dew point 76.  Even hotter temps not seen in five years expected on Friday.
« Last Edit: July 19, 2018, 05:57:46 PM by Bunty »
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #310 on: July 19, 2018, 09:22:08 PM »
This was my CumuluxMX page today on my Davis.
Weather radios:
Reecom R-1650
Sangean CL-100
« Reply #311 on: July 20, 2018, 12:58:35 AM »
WOW, Tulsa had even higher humidity to deal with.  Meanwhile, Oklahoma heatwave buckles Cimarron Turnpike pavement, lane closed on Stillwater spur:  http://www.stwnewspress.com/news/local_news/heat-buckles-cimarron-turnpike-pavement-lane-closed-on-stillwater-spur/article_1dd1fb57-0ca0-58ef-a6df-3992cef7991c.html
« Last Edit: July 20, 2018, 02:54:59 AM by Bunty »
    • LiVE WEATHER
« Reply #312 on: July 20, 2018, 06:18:38 AM »
There is a huge thread about the Davis SHT31 humidity reliability primarily having a high bias 5-8% humidity especially when hot and humid. Davis is actually taking a serious look into what may be causing this issue.
FYI I've got a couple acurite sht31's that don't display the same high bias so it may very well be the way chip is molded into board or handling, shipping sensors and storing in bubble wrap. The handling procedure stresses to avoid any plastics made of polyethylene which is almost all plus sensor shouldn't be open air but stored in appropriate bags. None of this was being done.
https://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/2_Humidity_Sensors/Sensirion_Humidity_Sensors_Handling_Instructions.pdf
These were the peak heat index readings at Tulsa and Stillwater yesterday at airports. Compare to the Davis stations if you own one.
krvs-109
ktul-114
KOWP -111
KSWO-113 Stillwater
Randy
Offline Intheswamp
    • Beeweather
« Reply #313 on: July 20, 2018, 09:40:25 AM »
That makes me think of the melting witch in the Wizard of Oz.....  :shock:
Davis VP2, v3.12
Cumulus v1.9.4  Build 1079
www.beeweather.com
Tried to lift one of vreihen's gold stars but wasn't smart enough to do it....<grin>
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #314 on: July 20, 2018, 04:04:38 PM »
I live in a bit of a microclimate; my humidity is always higher than the airport.  Live in a depression that's quite a bit lower in elevation next to a rather large creek.  The mixing creates more moisture for me.  I used to think I had bad weather units but this exists across three different weather station brands and I've verified with a sling psych.  It's no fun if I have to mow in this.  I try and mow early in the morning.
Weather radios:
Reecom R-1650
Sangean CL-100
« Reply #315 on: July 20, 2018, 04:41:32 PM »
I don't live in a depression, so I call into question the accuracy of the humidity reading on my Davis.  The current temp here is temp 106 with 118 heat index.  NWS said heat index would get up to 113.
    • LiVE WEATHER
« Reply #316 on: July 20, 2018, 06:57:02 PM »
Looking at Stillwater 109F 113 heat index at airport. Ouch! keep it down in Oklahoma..We had 112 ambient airport 108 at my station last year & no fun, doesn't take much humidity to make it feel real bad.
Randy
    • LiVE WEATHER
« Reply #317 on: July 20, 2018, 07:02:29 PM »
Very good. I really need to guywire my telepole. It turned into a propeller the pole bent so far over at peak wind so only recorded 60mph. I've had 72 before and pole didn't bend that far so actual was more in 80-85 mph likely.
Randy
« Reply #318 on: July 20, 2018, 07:30:02 PM »
My turn early next week. Progged for 111F Tue., no big deal here, but dews will probably hang on enough to put us around a 115F index. Excessive heat warning is already out.
« Reply #319 on: July 21, 2018, 01:09:54 AM »
Friday high at my station was 109.5.  Heat made turnpike buckle again with pictures:  http://www.stwnewspress.com/news/breaking-more-pavement-buckles-on-stillwater-spur-of-cimarron-turnpike/article_eef3568a-8c70-11e8-bbb4-7becb3f69d48.html
« Last Edit: July 21, 2018, 01:16:27 AM by Bunty »
Offline DRoberts
« Reply #320 on: July 22, 2018, 08:20:09 AM »
This sounds refreshing for us. Hope it somehow gets to OK as well:
NWS HSI forecast discussion 22 July
"We will be heading into a significant cool stretch to end the month
of July. This will begin on Thursday, as high temperatures only
reach the upper 70s to low 80s. It doesn`t look like we`ll get
cool enough to threaten any records at this time, but we aren`t
looking at any more 90 degree days through the end of July."
Offline Snowman11
« Reply #321 on: July 22, 2018, 09:29:23 AM »
Mostly cloudy here after a pretty good soaking overnight
« Reply #322 on: July 22, 2018, 11:27:03 AM »
119 Heat Index here yesterday. Don't think I could have been any more wetter after cutting the grass unless I took a shower.
Slight risk today also as the weather radio just went off with a Severe TS Watch.
Low probability of tornadoes just enhanced straight line and possible downbursts.
I probably should gas up the genny just in case.
    • LiVE WEATHER
« Reply #323 on: July 22, 2018, 11:46:54 AM »
Was that with the Davis station or airport. Many have noticed the Davis has a really high heat index bias with humidity running for some 10% high especially when it gets muggy.
Pulling up yesterday the Ocala International Airport - Jim Taylor Field, FL. reported high temp of 91.4F at dewpoint 77 making for heat index of 105.
Randy
« Reply #324 on: July 22, 2018, 12:09:09 PM »
It was the Davis. Does the new sensor rectify that?
