Author Topic: Eterlogic VSPE  (Read 1884 times)
Offline SierraFoothills
    • Rail Road Flat Weather
Eterlogic VSPE
« on: February 26, 2018, 03:47:36 PM »
Does anyone know if the Eterlogic serial port emulator by itself
http://www.eterlogic.com/Products.VSPE.html
can be used to run VWS and WeatherLink on the same computer? I am using VWS but would like some of the features of Weatherlink. The 32bit driver is free.
mike
Windows 7 32Bit
Davis VP2 Firmware Rev 3.63
Weatherlink USB in serial mode
WeatherLink v6.03
Virtual Weather Station v15 p05
http://weather.railroadflat.org
« Last Edit: February 26, 2018, 06:55:12 PM by SierraFoothills »
Re: Eterlogic VSPE
« Reply #1 on: February 26, 2018, 07:25:16 PM »
That's a No .. You would need to run VirtualVP to offer separate ports.  The problem is that VirtualVP does not support firmware above 1.90 (AFAIK) and since you have a new Davis system, VirtualVP wouldn't work with it.  Sorry...
The VSPE software just provides a 'null modem' connection between two serial ports (a pair).  I use it with VirtualVP (and my old VP1+ console) to map pairs like COM5-COM15, COM6-COM16 (etc) and VirtualVP offers COM15, COM16 (etc) and the weather software connects to COM5, COM6 etc.
So, with your new firmware, you won't be able to run more than one weather software at a time :(
Re: Eterlogic VSPE
« Reply #2 on: February 26, 2018, 07:48:49 PM »
Thanks. Do you happen to know if there is a hardware solution?
mike
Online johnd
Re: Eterlogic VSPE
« Reply #3 on: February 27, 2018, 07:21:51 AM »
There isn't. At least, not other than running a second console/logger (assuming that it's a wireless station) and hence having a second independent feed of data.
Littleport, Ely, Cambs UK
Offline AZmonsooncats
  • Current weather conditions in North Phoenix, Ariz
  • Me & My Little Sis!!
    • Pepper Ridge North Valley  Weather and Lightning
Re: Eterlogic VSPE
« Reply #4 on: February 05, 2019, 07:12:22 PM »
Been asking in my other post  about upgrading my computer, but is this the driver that will be necessary to run Virtual Vp, with Weatherlink, Vp Live and Weather display on my new windows 10 computer? It should be arriving in a few days and trying to figure out how to get everything up and running from my old xp computer. Note I do have the older firmware in my Vantage Pro 2 console since I never upgraded it. The new computer will have a serial port on a pCIe card.
Needing Advise on a replacement Computer as the old machine is on it's last leg.
Jeanette
« Last Edit: February 05, 2019, 07:13:53 PM by AZmonsooncats »
"Some dreams are in the night time, And some seem like yesterday
But leaves turn brown and fade, Ships sail away
You long to say a thousand words…but Seasons Change."
    • Conditions @ CW2274
Re: Eterlogic VSPE
« Reply #5 on: February 05, 2019, 07:20:47 PM »
I posted a full install of WL 6.0.3. for you on the other thread.
Re: Eterlogic VSPE
« Reply #6 on: February 07, 2019, 07:40:14 PM »
Well the new computer arrived today a Dell Optiplex 7060 It is my understanding that this driver will allow me to connect my virtual Vp with weatherlink 5.7.1, weather display and vp live on a windows 10 computer? Hopefully that is right any feedback on this would be appreciated I assuming this is a easy install, is worth getting the disk for a back up?
Thank you I consider the upgrade in weatherlink but is it compatible with the older firmware? Mine is original firmware from 2007.
Jeanette
« Last Edit: February 07, 2019, 07:55:04 PM by AZmonsooncats »
Re: Eterlogic VSPE
« Reply #7 on: February 17, 2019, 11:44:24 PM »
Update finally got weatherlink5.7.1 and latest weather-display working on the new computer, although I can run only one program at a time right now until I get VSPE api key to try to run multiple programs again. I assuming the key is necessary to run the virtual serial port emulator. I have not installed virtual vp or vp live yet until I receive the info. Please give me feedback on this I am assuming my thoughts on this are correct
Jeanette
« Last Edit: February 17, 2019, 11:47:38 PM by AZmonsooncats »
Re: Eterlogic VSPE
« Reply #8 on: February 18, 2019, 11:31:17 AM »
Jeanette, VSPE needs a Windows program key to be fully functional on your system for 64bit use.   http://www.eterlogic.com/Products.VSPE.html costs $24
Re: Eterlogic VSPE
« Reply #9 on: February 18, 2019, 12:54:40 PM »
Does VSPE work on Win 10?
Re: Eterlogic VSPE
« Reply #10 on: February 18, 2019, 01:30:07 PM »
Works fine on Windows 10 Home and Pro.
