Author Topic: This crazy error...  (Read 1496 times)
Offline mkutche
    • GosportWx.com
Re: This crazy error...
« Reply #25 on: February 20, 2018, 05:04:04 PM »
Hmmm....
That could be part of the issue right there. There ought to be a way to delete those inbox files, especially if you aren't using them. How many are in there, by chance?
Also, do you have a folder in your public_html directory called "alertlog"? If so, see what is in there, and if there is anything, delete it, and see if that makes any difference.
In that screen shot, there is a folder called logs. Look and see if there are files/folders in there.
Loads of files in that "mail" folder I called support he said that's the problem and to delete those. So I'm deleting those atm hopefully the guy is right ..
Mike K.
WS2080 - Cumulus MX v3.0.0
Gosport, Indiana
Gosportwx.com Gosportwx.com/PWS/ Gosportwx.com/j-template/ twitter.com/GosportINWX facebook.com/GosportINWX
Offline sacreyweather
  • Echo Valley Weather
« Reply #26 on: February 20, 2018, 05:05:26 PM »
Hopefully that solves the problem.
CWOP: D2073, GR2AE, GR3, Cumulus, PWSweather,  CoCoRaHS: AR-SL-23
Saline Weather on Twitter
Blitzortung Station 1387
Offline mkutche
    • GosportWx.com
« Reply #27 on: February 20, 2018, 05:11:14 PM »
Yep that is the problem its somethin to do with Cron the way I have it setup http://prntscr.com/ihjgsf but idk how to use godaddy cron for j-template.. ignore the other cron i had goin
Mike K.
Gosport, Indiana
« Reply #28 on: February 20, 2018, 05:16:11 PM »
Glad you found the issue. Can you set the CRON to only mail you if there is a problem?
Offline mkutche
    • GosportWx.com
« Reply #29 on: February 20, 2018, 05:17:25 PM »
im not sure i thought i used another cron site besides godaddy but i will look into that once im done with this problem. :)
Mike K.
Gosport, Indiana
« Reply #30 on: February 20, 2018, 05:18:56 PM »
I am using easycron.com for mine and like it a bunch. Cost is $20 a year. I use it for NWS Alerts, River updates, Blitzortung lightning updates, etc.
Offline mkutche
    • GosportWx.com
« Reply #31 on: February 20, 2018, 05:20:32 PM »
Much better!
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #32 on: February 20, 2018, 05:21:42 PM »
I use something i just can't remember the name of it LOL
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #33 on: February 20, 2018, 05:23:08 PM »
OK found it i use https://cron-job.org/en/
Mike K.
Gosport, Indiana
« Reply #34 on: February 20, 2018, 05:29:35 PM »
I have my NWS Alerts to update every 5 minutes normally, but when I know severe weather is about, I activate another CRON to update every 2 minutes, which is as fastas the NWS updates. My Blitzortung updates every 5 minutes, and my River Forecast page updates every 20 minutes.
Offline mkutche
    • GosportWx.com
« Reply #35 on: February 20, 2018, 05:33:23 PM »
Cool, I'm usually at work when bad weather hits lol
Mike K.
Gosport, Indiana
