Author Topic: Does WX need these Image Files  (Read 340 times)
Offline yamiacaveman
    • Penn Lake Weather
« on: February 16, 2018, 11:40:30 AM »
Ok, I posted this question on both the WD and WX forums, because, I think, to get my answer both might be involved.
So below, are an example of files that have been accumulating in my servers root directory, probably going back to 2005.
My question is do I need to have WD upload all these files to be used with the Wx template or does the Wx template use other information uploaded by WD?
The files below, if not needed for Wx, can I delete them and then stop having WD uploading them? If needed, where/how directions to set up an individual folder for each so they are not scattered all about my server.
Thanks for any suggestions! I hope I am not too confusing?
Are they just image files being created in case I wanted to display them or are they need by Wx?
September2013.htm
dailynoaareport122010.htm
climatedataout12010.html
Below are links that I use in Wx, do they use the files above or is there a different source?
Weather Trends    http://www.pennlake.us/wxtrends.php
History           http://www.pennlake.us/wxhistory.php
Almanac/Station Graphs    http://www.pennlake.us/wxgraphs.php
Daily Details/
   Daily Details http://www.pennlake.us/wxtempdetail.php
 Monthly Summary              http://www.pennlake.us/wxtempsummary.php?r=wxtempsummary.php
Seasonal Summary
http://www.pennlake.us/wxtempseason.php?r=wxtempseason.php
Re: Does WX need these Image Files
« Reply #1 on: February 16, 2018, 12:10:15 PM »
Good questions...
The wxtrends.php uses none of the files cited (only testtags.php and the windrose image).
The wxhistory.php page uses the September20xx.htm (and the others of MonthnameYYYY.htm files and the YYYYMMDD.jpg files)
The wxgraphs.php page uses images you haven't listed (curr24hourgraph.jpg, curr72hourgraph.jpg, monthtodate.jpg )
The wxtempdetail.php, wxtempsummary.php and wxtempseason.php scripts are not mine, but likely use one or the other of the three .html files you cited (dailynoaareportmmyyyy.html climatedataoutmmyyyy.html Monthnameyyyy.htm).  You'll have to examine each script to see what file it is looking for.
The windtempraintrend9.jpg is not used by any of my scripts for display.
Hope this helps.
    • Penn Lake Weather
« Reply #2 on: February 16, 2018, 01:03:17 PM »
Yes Ken, It certainly does help -- and also gives me some direction on where to head next.
The curr24hourgraph.jpg, curr72hourgraph.jpg, monthtodate.jpg, I only have one each, so must get over written(?). The others just keep growing.
« Reply #3 on: February 16, 2018, 01:21:35 PM »
Yes, those 3 .jpg files are uploaded and overwritten by WD.  The .*htm[l] files are uploaded once per day and change names with each month/year.
And the other scripts you cited that are not mine are Murray's scripts from http://weather.wildwoodnaturist.com/downloads.php
It says there that
You need to be uploading the dailynoaareport*.htm and climatedataout*.html files to your website.
so that answers your question :)
    • Penn Lake Weather
« Reply #4 on: February 16, 2018, 02:55:58 PM »
Again thanks for the info Ken.
So now I have to find out how to make those files from WD upload into there own directories and then adjust those php scripts that use them, tell them whee to find them.
For a caveman that's a challenge, lol.
Again thanks for all your help!!!
