Author Topic: Battery / solar / supercap issue  (Read 804 times)
Offline martymoose
« on: February 10, 2018, 09:01:15 PM »
it's a vp2 wireless
Had a bit of a look around, really didn't see any info
Heres The issue
every 6 months unit goes flat kind off
battery goes flat, have replaced the supercap couple of times as per members advice
the unit only sends data when the suns up ie 6 am to 6 pm
I think the super cap doesn't get any charge
anyone else had this issue
also, console always says battery low on the iss even with new cap and battery
or is the battery only to last 6months
cheers
Offline dalecoy
    • Lee's Summit, MO
Re: Battery / solar / supercap issue
« Reply #1 on: February 10, 2018, 09:49:53 PM »
Is that the way it operates, when the battery is new?  Or just how it works after 6 months?
In any case, if you have correctly replaced the supercap, then the problem is somewhere in the connecting circuitry.  Unless you are technically skilled, you will need a new ISS circuit board.
Offline martymoose
« Reply #2 on: February 10, 2018, 09:51:44 PM »
Yea was thinking that
Ill just keep replacing battery
Bought rechargeable ones this time
Sent from my SM-G950F using Tapatalk
Offline JohnDoe1983
  • Hi !
  • Just love to watch the weather
    • John station
« Reply #3 on: February 10, 2018, 10:48:10 PM »
Hi!
What brand and model of rechargeable battery did you buy?
Thanks.
Quebec
Canada
Ex-weather man
Davis Vantage Vue
Oregon WMR200
Lacrosse
http://www.wunderground.com/personal-weather-station/dashboard?ID=IQUEBECQ10#history
Offline martymoose
« Reply #4 on: February 11, 2018, 12:09:19 AM »
Hi!
Thanks.
Ill have to a look ebay i think
I tried the lithium and normal alkaline  all the same 6-8 months
Offline johnd
« Reply #5 on: February 11, 2018, 04:33:26 AM »
Please remember that it's not recommended by Davis to use rechargeables in the ISS - the voltage characteristics are sufficiently different from the CR123.
Littleport, Ely, Cambs UK
Offline martymoose
« Reply #6 on: February 11, 2018, 05:33:04 AM »
Sweet thanks for that ill get some energizers
Offline eliteweathernz
  • Weather Equipment Sales
    • Elite Weather Systems NZ
« Reply #7 on: February 16, 2018, 01:12:56 PM »
Definitely an issue with your ISS board, replace it and youll be back to normal.
Id also check the voltage from your solar panel on the front lid.
Offline martymoose
« Reply #8 on: February 16, 2018, 03:44:33 PM »
Will do thanks mate
Offline dalecoy
    • Lee's Summit, MO
« Reply #9 on: February 16, 2018, 05:23:04 PM »
I think I suggested that earlier (unless you want to just keep replacing batteries every few weeks).
