September 03, 2010, 03:51:31 PM *
Did you miss your activation email?
Members: 3159  •  Posts: 81804  •  Topics: 8352
Please welcome MonsonWx, our newest member.
Problems with the forum? Please PM saratogaWX with details. Thanks!
Author Topic: VWS p64 Barometer Offset?  (Read 699 times)
mikewren
« on: February 15, 2009, 09:20:33 AM »
The current barometer reading is being outputed via HTML template ("^vxv008^") .5 in/hg low for me.  All other display is correct, including in software, and via WeatherBug and WUnderground.
I set a + .5 offset in the ASP code where I'm using the HTML template until a less kludgy resolution is found.
Barometer output was as expected in versions prior to p57.  Any suggestions?
tomcj2
« Reply #1 on: February 15, 2009, 11:43:16 AM »
What station do you have?
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
mikewren
« Reply #2 on: February 15, 2009, 11:49:01 AM »
Sorry, should have included more info;  We have the VP2 with the serial data logger.
Very detailed info about our system is at http://mikewren.com/websterweather
« Last Edit: February 15, 2009, 11:52:12 AM by mikewren » Logged
tomcj2
« Reply #3 on: February 15, 2009, 01:05:33 PM »
I have only had luck changing my barometer using WeatherLink
(do you have al page that shows your actual weather? )
« Last Edit: February 15, 2009, 01:07:40 PM by tomcj2 » Logged
mikewren
« Reply #4 on: February 15, 2009, 01:25:39 PM »
It's in my sig and on the technical page:
http://websterweather.com
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.059 seconds with 18 queries.
