Author Topic: ajax-dashboard.php and php7  (Read 679 times)
Offline bob_linux_user
    • W4LCS Weather
« on: February 01, 2018, 05:57:46 PM »
Forgive me if this has been asked before. I updated one of my RPi2 to Debian 9 and discovered that the ajax-dashboard.php will not display. All other php files work and ajax works. Is it possible to use php7?
Bob
Offline Toxic
  • #conligwx
    • conligwx.org
Re: ajax-dashboard.php and php7
« Reply #1 on: February 01, 2018, 06:07:36 PM »
Using php 7.1.13 and ajax dashboard here ok.
    • W4LCS Weather
« Reply #2 on: February 01, 2018, 06:19:34 PM »
That is good to know. I must have a problem on my end. I will continue to investigate..It could be in Wxindex.php not getting to that point. How do I enable the Debug code and where does it create a .txt file?
Bob
« Reply #3 on: February 01, 2018, 09:59:39 PM »
Check the error_log for your webserver -- it will have the diagnostic info you need to find the error.
Your http://www.w4lcs.com/ site seems to show the dashboard now.
You can use check-fetch-times.php?show=info on your site to make sure you have curl and gd functions available.
use check-fetch-times.php?show=versions to make sure you have key files at current levels.
Yes, it works fine with PHP 7.*
« Last Edit: February 01, 2018, 10:02:21 PM by saratogaWX »
    • W4LCS Weather
« Reply #4 on: February 02, 2018, 07:13:24 AM »
Thanks for the reply. Yes, my online system is working fine now on Debian Jessie. I a took a spare Pi2 and did a new install of Debian Stretch Lite to see if I could do the upgrade to Debian 9. I now have it working after commenting out the call to atom-top-warning.php. There is something there that php7 does not like. I am going to troubleshoot that today. My plan is to have a production system that is free of the bulk from the old wview and years of upgrades. I did not do a fresh install of Jessie when I began this project and there is still a lot of fat on the system.
Bob
Offline Toxic
  • #conligwx
    • conligwx.org
« Reply #5 on: February 02, 2018, 08:57:25 AM »
As Ken says, check the apache error logs first. If they are inconclusive, then enable debug on apache log level and see what it is that is causing the issue.
    • W4LCS Weather
« Reply #6 on: February 02, 2018, 01:23:19 PM »
Thanks for the help. Everything is working well on Debian 9 with php7. The check-fetch-times.php is a great tool. I had run it before but without the ?show=info and ?show=versions. I had some php7 additions to install. Additionally, I thought that I had the latest Base USA software but found that there were some new files after the Base USA was zipped. Thanks to all.  =D>
Bob
