Author Topic: Will there be a version for the Access?  (Read 3407 times)
Offline skysummit
    • StormCast
« on: January 11, 2018, 11:49:13 PM »
Kevin,
Just wondering if you were working on a version for the Acurite Access since it's the hardware that's currently replacing the Smart HUB, and I'm sure that one day the HUB will be extinct.  Since the Access just recently became available, I'm sure you haven't had much time yet to look into it.
Just wondering if it's a possibility.
Hardware:  Acurite Atlas with Lightning Detector
CoCoRaHs Station: LA-TG-11
NWS's Ponchatoula/Hammond Area's COOP Member
President | Director of Operations - StormCast
Offline ColoradoWeather
  • Ambient Weather WS-2000
    • KCOFORTC421 - Hanna Farm
Re: Will there be a version for the Access?
« Reply #1 on: January 23, 2018, 07:55:34 PM »
I don't believe the "Atlas" is available as of yet.  There is also the issue that it has been reported that the data stream is encrypted. This would make parsing it extremely difficult.
Ambient Weather WS-2000 Weather Station
Home Weather Server:
http://kcofortc64.dlinkddns.com/WD/wx.html
Weather Underground Link:
https://www.wunderground.com/dashboard/pws/KCOFORTC421
PWS Weather Link:
https://www.pwsweather.com/obs/KCOFORTC421.html
Offline DoctorKnow
« Reply #2 on: January 23, 2018, 08:42:54 PM »
On the test version, the data is encrypted. I hope the new models that are going out are not, but I don't think anyone has tested them yet?
Offline nincehelser
« Reply #3 on: January 23, 2018, 10:49:51 PM »
Even if you dance around the encryption problem, data is only sent to myAcurite in 5-minute intervals, so that may not be terribly useful.
Sniffing the wunderground stream makes more sense as it is not encrypted and sent in real-time.  The disadvantage is that you'll only be able to pick up data from one sensor.
Offline WonderWX
« Reply #4 on: January 25, 2018, 05:12:15 PM »
retrieving data from the device will be the new hotness  :evil:
« Reply #5 on: January 27, 2018, 04:00:57 PM »
Right now I am using different sensors for Temperature/Humidity and the 5in1 for the rest. I like this feature offered by Kevin's Software. I also use my data locally to run my own web server in real time (18sec). I definitely don't want to lose that ability. Just have to be patient and stay positive about the new weather station for now. It looks like a great piece of hardware!
« Last Edit: January 27, 2018, 04:04:07 PM by ColoradoWeather »
PWS Weather Link:
Offline DoctorKnow
« Reply #6 on: January 27, 2018, 04:29:45 PM »
The thermometer in the new Atlas is just as accurate as the tower thermo/hygro for temperature, and even more accurate for humidity response in my testing. This is winter testing, so when the heat comes, we will see how it does in the hot sun, but I really don't expect an issue there.
« Reply #7 on: January 30, 2018, 08:57:55 AM »
It looks like there is someone getting data from the Access Hub now!
https://github.com/acuparse/acuparse/issues/17
« Last Edit: January 30, 2018, 09:01:27 AM by ColoradoWeather »
PWS Weather Link:
Offline waiukuweather
« Reply #8 on: January 31, 2018, 04:31:32 AM »
good to see real robust debate about the pros and cons of the new Acurite products on that github project
seems the windspeed updates are a little less to be desired?
Offline nincehelser
« Reply #9 on: January 31, 2018, 09:07:41 AM »
What "debate" are you talking about?
We are talking about the reporting interval of the 5n1, not the Atlas.
« Reply #10 on: January 31, 2018, 03:23:05 PM »
what is the reporting interval of the new series of hardware then?
Offline nincehelser
« Reply #11 on: January 31, 2018, 03:32:42 PM »
The reporting interval of the Atlas is 10 seconds.
I'm not sure what the wind sampling window is, though.  On the 5n1 the windspeed sampling window is 4 seconds, not 18 seconds as many assume.
The reporting interval of the Atlas Elite is 2 seconds.
