Author Topic: Thunderboard from Silicon Labs new sensor and transmitter board  (Read 1879 times)
Offline DaleReid
    • Weather at Eau Claire, WI
« on: January 03, 2018, 08:13:19 PM »
I got an email from DigiKey about a new evaluation kit for less than $38 for those with tinkering expertise.  It is called a Sense 2 Thunderboard, and the link to tell more is here:
https://www.digikey.com/en/product-highlight/s/silicon-laboratories/thunderboard-sense-2-next-generation-iot-development-kit?utm_medium=email&utm_source=pie&utm_campaign=1801_PIE1801A&utm_content=P11_learnmore_US_336-Silicon_Labs&utm_cid=10226399&WT.v_sub=10226399&WT.mc_id=em_PIE1801A&WT.z_email=1801_PIE1801A0I1US_P11-learnmore--336-Silicon_Labs&mkt_tok=eyJpIjoiWTJGalpqWTVZemc0WkdGbCIsInQiOiJHa0x3YVVZOCt3XC8zTnk4djNhNytuc0VsYXhHajdBYUNiNGpwWU9tM2FLcm1EeDZjTU5HWnVKUnYxUnVsR20yaXZBSzdGczRLMFdTQVhzeVdxT2FjbDRydmcrZ2JZK1ByaDQ4cHM1QTRjUDZRY0VrZWtcLzhMVncxd0JnS1JiMVpFIn0%3D
Why such a long link I have no idea.
Or go to DigiKey and look up the SLTB004A evaluation board kit.
It has sensors for:
    Relative humidity and temperature sensor Si7021
    UV and ambient light sensor Si1133
    Magnetic Hall effect sensor Si7210
    Pressure sensor BMP280
    Indoor air quality and gas sensor CCS811
    6-axis inertial sensor ICM-20648
    TDK InvenSense ICS-43434 microphone
as possibilities.
ECWx.info
ECWx.info/t/index.php
Offline DaleReid
Re: Thunderboard from Silicon Labs new sensor and transmitter board
« Reply #1 on: January 03, 2018, 08:17:10 PM »
Here's the pdf
ECWx.info
Offline SLOweather
    • Weatherelement Moline IL
« Reply #2 on: January 03, 2018, 08:39:29 PM »
The only important part is that up to the first ?. https://www.digikey.com/en/product-highlight/s/silicon-laboratories/thunderboard-sense-2-next-generation-iot-development-kit
The rest is tracking info for where you saw the link etc.
Try it. That truncated link I posted works.
Offline DaleReid
« Reply #3 on: January 03, 2018, 08:48:21 PM »
Thanks, I didn't know I could cut the rest off.
Have you built on of the boards yet?
Come on, get on the stick.
ECWx.info
Offline SLOweather
« Reply #4 on: January 04, 2018, 09:52:51 AM »
Certainly looks interesting for only $36.25...
Offline SLOweather
« Reply #5 on: January 07, 2018, 09:57:12 AM »
Ok, Ok, Geeze...
Offline DaleReid
« Reply #6 on: January 07, 2018, 10:57:44 AM »
Wow, you need to talk with my wife.  You do more things I suggest than she does!  (You knew I was kidding, right, but I'm glad you snabbed one to play with.)
Can you give an update on whether more of us ought to grab one to play with or not?  Looks promising, as you said.
Thanks. Dale
ECWx.info
Offline vreihen
  • El Niņo chaser
  • K2BIG
« Reply #7 on: January 07, 2018, 11:14:53 AM »
I'd be curious to know if it can be used with the Arduino SDK, or if it requires a completely different developer tool chain to make any use of it?????
