Author Topic: OK This is just crazy cold  (Read 522 times)
« on: January 02, 2018, 08:55:20 AM »
It was 4F just a few minutes ago.  The cold air has been easing into the area for the past couple of days.  I'm hoping things will warm after today.  It's my understanding that we were on the edge of the huge air mass.  I'm sure the people in Fargo, ND just shrug and go about their business.  I'm starting the new year thinking I may retire to somewhere warm where it doesn't get below 40F.   Brrrrr.
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
Re: OK This is just crazy cold
« Reply #1 on: January 02, 2018, 09:10:10 AM »
Yep, been pretty cold here too.  Warmer does sound better  :grin:
Davis Vantage Pro2, Serial Data Logger
WD 10.37S-(b60), VWS V15.00p03, Weatherlink 6.0.3,  Fling 2.35, Broadwave 2.0, Win 7 Pro 64Bit
KMICHEBO10 - CW3699 - Cheboygan, MI
Offline PaulMy
« Reply #2 on: January 02, 2018, 09:42:28 AM »
This continued cold is affecting a large area... and particularly the last week of December.  Our coldest is usually late January and early February.
http://www.komokaweather.com/mysql/monthly-temp.php
http://www.komokaweather.com/mysql/monthly-data.php
http://www.komokaweather.com/weather/betel_datasummaryCU.php
Brrr
Offline BeaverMeadow
« Reply #3 on: January 02, 2018, 10:06:25 AM »
Last autumn the NWS was predicting a warmer than normal winter for New England. I always thought this kind of mid-term forecasting was highly questionable. Now I am convinced that it is pretty much worthless.
Offline Aardvark
  • www.desmoinesweather.org
    • Des Moines Iowa Weather and Climate
« Reply #4 on: January 02, 2018, 10:07:16 AM »
It is just nasty.   Right now -13.9F.   it has been below zero around the clock in Iowa.   Windchills are terrible. Maybe, just Maybe  next Monday we see 24 F .
The serious part is that the roads around here have a thin layer of ice, making it slippery. with the seriously below zero temps,  the traditional ice melting chemicals are worthless.
And  it is only January.
« Last Edit: January 02, 2018, 10:41:56 AM by Aardvark »
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP;USB; MAC Sierra; Bloomsky 2 ;https://map.bloomsky.com/weather-stations/faBiuZWsnpW6n6il
http://www.desmoinesweather.org
Offline DoctorKnow
« Reply #5 on: January 02, 2018, 10:26:00 AM »
It is just nasty.   Right now -13.9F.   it has been below zero around the clock in Iowa.   Windchills are terrible. Maybe, just Maybe  next Monday we see 24 F .   Welcome to the wonderful world of messing with the environment, Mr.  T.
How has Mr. T "messed with the environment"? That was MR. BIgshot O. He was doing the manipulation and declaring a war on weather saying it was a threat to security.
    • Robbinsdale Middle School Weather
« Reply #6 on: January 02, 2018, 10:36:26 AM »
stop the politics-thank you.
We have been below zero since Friday. All but one hour or so.
I have posted a few times in other threads about pop in the garage exploding.
Slow modem-I was not real keen on sending my kid back to Fargo yesterday. Yes, her car runs fine, but you never know when it will get icy. This cold, water from car exhaust freezes on the road and will not be thawed by the salt on the roads. I tracked her almost the entire way home and back.
I am at school today preparing for next week. I slid a little bit on the way in. But for us, warmth means snow. It is supposed to snow tonight and a little later in the week. Yes, it can be too cold to snow.
Vantage Pro Plus 6163
Offline Aardvark
« Reply #7 on: January 02, 2018, 10:45:39 AM »
Iowa schools are starting back this week. Des Moines tomorrow.  Colleges on Friday. Universities on the 15th.   I am home with coffee. :)
 We have had some major housing fires,  people need to be careful. An apartment complex went up in flames yesterday.  32 people homeless -condos.
I think next summer , I willl spring for a new furnace. I had a new airconditioner put in last summer, the furnace is getting a bit old, a Trane,  so Maybe in May I can have it done. I am getting older and the wife won't remember it.
But fire prevention should be in your lesson plans somewhere..
The weather equipment is working right now
Offline SoMDWx
    • Southern Maryland Weather
« Reply #8 on: January 02, 2018, 10:59:13 AM »
Hopefully all of you have sufficient heat.. My furnace went out Thursday night and I have a small gas stove in the basement which heats just the basement but not the rest of the house...
ARGH!
Jim Wyman
http://somdweather.com
http://scit.somdweather.com
« Reply #9 on: January 02, 2018, 11:29:09 AM »
Aardvark-I have been by those. Someone prob with a small heater.
The Waterloo suburb of Evansdale lost water service for a time Monday after temperatures fell to minus 20 degrees (-29 Celsius). Mayor Doug Faas (fahs) said Tuesday that water is being run directly from the wells into the system, bypassing the suspected ice blockage in the tower.
A city staffer is expected to climb the tower later Tuesday to see what's wrong and determine how to fix the problem.
In the northwest Indiana city of Lafayette, residents began hearing a hum that Duke Energy says is caused by extra power surging through utility lines to meet power demands during the Arctic blast. Monday's low fell to minus 16 degrees at the National Weather Service's Purdue Airport station in adjacent West Lafayette.
« Last Edit: January 02, 2018, 11:47:27 AM by chief-david »
Offline ValentineWeather
« Reply #10 on: January 02, 2018, 11:41:59 AM »
One of the colder stretches here in the 4 winters since moving in. Received the rest of pre paid summer fill propane today 100 gallons and he said I had room for 18 more gallons  so 118 gallons used since fill in September. Not bad at all considering but November was well above normal.
I did add insulation last summer R-60+ roof and think it may pay off in a couple winters plus house had a new Carrier furnace added 20 seer just prior to moving in.  Since Christmas temperatures.... ;)
Randy, the Aviator is my father in 1963 with his Indian bike
« Reply #11 on: January 02, 2018, 11:49:03 AM »
YOu could be these people. Jumping into Lake Minnetonka for charity.
it was -6 yesterday.
http://video.startribune.com/people-brave-subzero-temps-jump-into-lake-minnetonka/467558733/
« Reply #12 on: January 02, 2018, 12:01:14 PM »
Braving the cold chating with propane guy.  :-)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
« Reply #13 on: January 02, 2018, 12:17:18 PM »
My skycam computer will not keep running in the cold anymore. I turn it on and it turns off.
I will try the computer again when it gets warmer out. But it don't look good for it.
My bloomsky weather station thing dies about 3AM because its batteries are cold I guess. and it comes back to life when the sun gets on it. I did see that its wind speed will not spin anymore also. Hope it is just frozen and not just broken.
it's a little warmer here today. my low yesterday was -13F today it was only -10F
My BloomSky Station
Blitzortung Station #1328
Anthony
« Reply #14 on: January 02, 2018, 12:50:43 PM »
Even the moles are COLD! ...Jan 2nd 2018 soil temperatures at 9am today
« Reply #15 on: January 02, 2018, 01:03:08 PM »
"My bloomsky weather station thing dies about 3AM because its batteries are cold I guess. and it comes back to life when the sun gets on it. I did see that its wind speed will not spin anymore also. Hope it is just frozen and not just broken. "
Have you tried lithium batteries?
Offline nincehelser
    • nincehelser.com
« Reply #16 on: January 02, 2018, 01:56:49 PM »
Bloomskys have their own custom internal battery.  I think it's lithium-ion, but don't quote me on that.
I power mine directly from the AC adapter.  I guess it's been that way for a couple of years now with no problems except when someone unplugs it.
« Reply #17 on: January 02, 2018, 05:18:03 PM »
« Reply #18 on: January 02, 2018, 07:05:32 PM »
The first time I read that, I thought you said February.  :o
« Reply #19 on: January 02, 2018, 07:54:08 PM »
Wow! I'm thankful we haven't seen zero.  I hope all y'all up there are safe and warm.
    • http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KFLBELLE2
« Reply #20 on: January 02, 2018, 07:57:04 PM »
Don't see this for Florida too often.
significant snow and ice accumulations expected on Wednesday...
..Winter Storm Warning in effect for southeast Georgia and
portions of northeast Florida...
..Winter Weather Advisory in effect for portions of northeast
Florida...
If you can believe this the county schools actually called and said they are starting the bus's early so they are warmed up for the kids. And here's the kicker. If you as parents believe that it's too cold for your child to go to school tomorrow it will be an excused absence. :shock:
35 freakin degrees is too cold to go to school? I think I have heard it all now.
Offline MonumentHillWeather
    • Monument Hill Weather... Leeds, Maine
« Reply #21 on: January 02, 2018, 08:30:12 PM »
We have also been well below zero for the majority of the time since Christmas here in Maine. Our highest temp since Dec 25th was 11F and the lowest was -23F. Our past 10 day average is a mere -6F!
And it has been windy so the wind chills have been brutal. Coldest wind chill so far in this stretch of -38F.
And itís going to be even colder this upcoming weekend.
Oh and did I forget to mention it looks like we have our second blizzard of the season coming Thursday into Friday. And someone mentioned itís only the beginning of January?  :lol:
  - Matt
Monument Hill Weather... Leeds, Maine, USA
Davis Vantage Pro2 with Meteobridge & Cumulus V1.9.4
http://monumenthillweather.webs.com/
https://www.wunderground.com/personal-weather-station/dashboard?ID=KMELEEDS7
« Reply #22 on: January 02, 2018, 08:31:27 PM »
Florida...
Minnesota "Hold my beer"
« Reply #23 on: January 02, 2018, 08:40:45 PM »
Florida...
I'll bet there's going to be an all-day coverage on TWC tomorrow.  It could be  a really bad storm.  Luckily it's going to the south of me.  But the east coast is going to get slammed.
    • Conditions @ CW2274
« Reply #24 on: January 02, 2018, 09:07:42 PM »
As you know, I grew up in Vermilion. The ONLY thing that closed schools was drifting snow, or something like Jan. 1978, pressure at 28.28", and waking up to two feet from overnight.
Davis Wireless VP2 SHT31 24hr 67CFM FARS
RW Tipper w/ CoCoRaHS
