Author Topic: Need help setting up Virtual VP coms  (Read 5892 times)
Offline Tazz 316
Re: Need help setting up Virtual VP coms
« Reply #50 on: May 14, 2019, 09:11:35 PM »
Same here. 13 days and no issues.
 :grin:
Any updates? I eventually gave up it would work for days or a week but stop sending data restart would fix the issue.
Since then i have built a new PC and have been looking at trying it again. Or has anyone found another way to use multiple software? I see that meteobridge has a pass through.
« Last Edit: May 14, 2019, 09:14:57 PM by Tazz 316 »
Offline piconut
  • Juggler Extraordinaire
    • South Austin Weather
« Reply #51 on: June 08, 2019, 03:23:49 PM »
... I do that with multiple systems and have a VP1->virtualVP on one system->VirtualVP on a second system so I can run a bunch of weather software varieties (for testing with the templates).
How exactly do you have a second VirtualVP setup on a second computer that is fed by VirtualVP on the first computer?  What are the settings you have for both VirtualVP instances that allow for this?   Thanks!
  • Davis Vantage Pro 2
  • Virtual VP
  • Virtual Weather Station V15.00
  • Cumulus
  • Image Salsa
  • IP TimeLapse
Online gwwilk
  • Southeast Lincoln Weather
« Reply #52 on: June 09, 2019, 07:54:07 AM »
There are a couple more software programs involved: serial port emulators.  I use 'com0com' 64 bit on the dependent computers:
and N8VBvCom on the old 32 bit main computer:
The Main Computer's VVP:
and the Main Computer's VVP Settings:
The Dependent Computer's VVP:
and the Dependent Computer's VVP Settings:
In essence it isn't a trivial exercise to get everything set up properly so it works.  But it's well worth the effort.
(And as you can see my setup is very much 'over-the-top' with the backup computers and all.)
Regards, Jerry Wilkins
gwwilk@inebraska.com
« Reply #53 on: June 09, 2019, 08:52:54 AM »
Dayum!
Offline piconut
« Reply #54 on: June 13, 2019, 12:38:06 PM »
Dayum!
So I was under the impression that Virtual VP could only be set up to receive either a serial connection or an IP connection.  What I didn't realize is that if I only have a Vantage Pro 2 that communicates via serial, that Virtual VP will also communicate that information from serial to an IP address.  Am I understanding this correctly?
  • Virtual VP
  • Cumulus
  • Image Salsa
  • IP TimeLapse
Online gwwilk
« Reply #55 on: June 13, 2019, 12:56:15 PM »
@ piconut
I've only tested it on my LAN, and it works flawlessly as configured above.
