Author Topic: win10 x64 - running weatherlink and other weather apps simultaneously  (Read 1028 times)
Offline GeoAir.pt
Hello, season greetings.
Is there any proven solution to run weatherlink 6.0.3 (firmware 1.9) and other weather apps simultaneously in a win10 x64 environment ?
I have seen references to VirtualVP, VSPE-Virtual Serial Ports Emulator, com0com, and others, but i can't find a working solution for w10 x64.
Any suggestions?
Thank you
Edit: Weatherlink runs with usb datalogger
« Last Edit: December 26, 2017, 01:11:41 PM by GeoAir.pt »
Offline waiukuweather
Re: win10 x64 - running weatherlink and other weather apps simultaneously
« Reply #1 on: December 26, 2017, 01:23:55 PM »
VVP is the best solution
since you have an older firmware , it should work hopefully
have you tried it?
Offline GeoAir.pt
« Reply #2 on: December 27, 2017, 09:08:47 AM »
Thank you for your suggestion.
Managed to install VVP and successfully communicating with davis vantage pro console.
Since that I'm using a 64bit environment , whats the suggested method to create the virtual com ports, considering that VSPE in 64x version is paid?
Best regards.
