Author Topic: PWS Data Summary on Wundergroud  (Read 687 times)
Offline DrBobDavisV2
« on: December 24, 2017, 02:54:09 AM »
My Davis Pro V2 is up and running and sending data to Weatherlink, CWOP and Wunderground via "Vantage Connect" but the Summary fields on Wunderground are blank.  I've emailed them but really don't expect to hear back from them.  Has anyone come across this issue before?
https://www.wunderground.com/personal-weather-station/dashboard?ID=KFLVENUS8
Offline nincehelser
    • nincehelser.com
Re: PWS Data Summary on Wundergroud
« Reply #1 on: December 24, 2017, 03:36:43 AM »
I've seen a couple of other people complain of the same problem on Saturday.
It's been working for me, though.
I don't think it has anything to do with Davis... just wunderground.
« Reply #2 on: January 02, 2018, 11:02:03 AM »
Still no fix on the daily summary.  Multiple emails with no response whatsoever.  There has to be a common issue affecting all these stations that don't report a daily summary?
Offline wvdkuil
  • Wim van der kuil
    • Support site Leuven Template and scripts
« Reply #3 on: January 02, 2018, 12:35:08 PM »
This discussion has more complaints:
Weather Underground Summary not recording
https://www.wxforum.net/index.php?topic=33465.0;topicseen
Wim
Vantage VUE with a WLIP connected to a Meteobridge used for https://weer.sluispark.be/
Same VUE+WLIP uploads to WL.com(2.0)  used for https://sluispark.be/weather28/
Vantage VP2 with a USB logger/Meteobridge for https://www.weerstation-herent.be/
Envoy with a WLIP uploads to WL.com(1.0) as a backup / test for the same site.
« Reply #4 on: January 04, 2018, 01:37:01 PM »
Wunderground is making some headway...even though the feed is hit and miss, for the first time ever I'm seeing a Daily Summary online.  Progress...hopefully
Offline LABob
« Reply #5 on: January 04, 2018, 03:17:31 PM »
WU is getting worse from here. I can't load most pages at all. I just get an error from their server, or the "Oops! There's been a glitch." page.
Offline Catskin
« Reply #6 on: January 04, 2018, 04:25:03 PM »
Yeah but my WU IPCAM is back on line so there is that..
« Reply #7 on: January 04, 2018, 09:56:39 PM »
Quick update but it appears everything is hunky dorry with my PWS and the WU portal.
Offline AB4GR
« Reply #8 on: January 05, 2018, 05:32:41 AM »
I just got my station on the air yesterday. I've registered with Wunderground and PWSweather.com, but so far neither is showing my station. PWSWeather said to give them at least 48 hours, and with the Wunderground issues I don't expect mine to be showing up there anytime soon.
Are those the only two web sites that will display PWS infomation? I have an Ambient WS-2902.
« Reply #9 on: January 05, 2018, 07:16:26 AM »
assuming your using weatherlink 2.0
You can also upload to CWOP.  Check and make sure the station name is correct for WU in weatherlink.
Offline AB4GR
« Reply #10 on: January 05, 2018, 07:32:23 AM »
Unfortunately, using Weatherlink is apparently not an option with the WS-2902. At least without some additional cash outlay for interfaces.
