Author Topic: "Can not find Wi-Fi Network"  (Read 194 times)
Offline Sherry
« on: December 10, 2017, 06:00:38 PM »
A few months ago I got a WS 1001 and it's worked well (except for intermittent failures to connect to wifi) but now wifi seems gone for good. There's no wi-fi icon on panel and the wi-fi scan replies "Can not find Wi-Fi network" even though other devices are connected to same wi-fi with no problem.
So far I've tried turning both the panel and wifi off and back on again; resetting the panel and reentering everything, including WU station key; and turning off all other devices connected to the wifi. But nothing has worked so far.
I am leaving this house soon and will have no access to panel and wifi, so hope to hear from someone soon! Thank you!
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
Re: "Can not find Wi-Fi Network"
« Reply #1 on: December 26, 2017, 09:45:13 AM »
(...)  "Can not find Wi-Fi network" even though other devices are connected to same wi-fi with no problem. (...)
And when you bring the WS1001 console closer to the router, is there also a lack of range?
