Author Topic: Can't upload to Weathercloud  (Read 1738 times)
Offline zackdog
    • Winter Park Highlands Web cams
« on: December 05, 2017, 01:09:18 PM »
About three weeks ago, figuring WU will be no more in the future, I setup an account on Weathercloud.  After spending a good three hours following their vague instructions and not having any success, I just gave up.  Yesterday I received an email notifying me that I had not linked my station.  I contacted support and they sent detailed instructions.  I followed the instructions to the "T" and still am unable to link my station.  I am using Cumulus 1.9.4 build 1099.
Has anyone else had this problem?  Any help would be appreciated.
"You don't need a weatherman to know which way the wind blows." - Dylan
Vantage Pro2 Plus w/ 24 hr FARS and (2) VantageVues
VP2 uploading via Vue console to CWOP, WU, PWS, and Weathercloud.
Offline jas340
    • Lone Pine Ranch  Horseshoe Bend, Idaho  USA
Re: Can't upload to Weathercloud
« Reply #1 on: December 05, 2017, 01:26:30 PM »
Yes, same exact situation as you. Got the same email. My weather cam is linked but no data.
Offline PaulMy
« Reply #2 on: December 05, 2017, 01:42:01 PM »
I presume you have Adrian's program running http://sandaysoft.com/forum/viewtopic.php?f=4&t=11998&p=103501&hilit=weathercloud#p103501
Mine seems to be working ok http://app.weathercloud.net/d0280022074 but I can't recall what I had to do for the setup as before there was a Cumulus option I had originally signed up for Weathercloud by selecting Weatherlink and when I then actually used Cumulus about a year later I didn't need to make any changes to my Davis device.  Likely just enter the Weathercloud ID and key supplied by them.
p.s. and thanks for posting, it made me look at my site and found my webcam was down #-o
Enjoy,
Envoy/USB DataLogger/Cumulus v.1.9.4   -   Vue Console/WiFiLogger
Komoka, ON  Canada
www.komokaweather.ca   www.komokaweather.com   www.komokaweather.com/weather28/   www.komokaweather.com/pws/index.php
Offline zackdog
« Reply #3 on: December 05, 2017, 06:26:34 PM »
The instructions said to check Realtime if your logging interval is greater than ten minutes.  My logging interval was set at 15 minutes, so I naturally checked Realtime.
I just went in and unchecked Realtime and I am now linked and on Weathercloud.
Offline PaulMy
« Reply #4 on: December 05, 2017, 07:36:31 PM »
Great!
Enjoy,
Komoka, ON  Canada
Offline noraval
« Reply #5 on: July 09, 2018, 07:29:53 PM »
Hi guys,
I'm having issues uploading to weathercloud.
Not sure if i have it set up correctly thou...
local filename is C:\Cumulus\cumulus-weathercloud\weathercloud_realtime_template.txt
Remote filename is C:\Cumulus\cumulus-weathercloud\weathercloud_realtime.txt
I have real time off as I'm logging 1min intervals. Is this all correct?
Looking at the logs it looks like it is sending the same data over and over.
I've tried the setup several times and I am a little lost now. any help would be much appreciated!
Offline Jjm457
« Reply #6 on: July 14, 2018, 08:06:35 PM »
I've had luck on and off with  Weathercloud and Cumulus. Once I'm up and running it goes good for a while, however, it goes down if I have a thunderstorm and/or my PC and wifi go down.  Weathercloud will not come back up on it's own. Honestly,  I'm kind of tired messing with it!
