Author Topic: Tower Sensor(06002m/592TXR) Humidity sensor replacment??  (Read 409 times)
Offline daman
« on: November 15, 2017, 06:20:22 PM »
My TS is stuck on 98% I'm in the process if getting a new one through my warranty but would like to fix this one, can the sensor be un soldered and be replaced on this model?
AcuRite 01057RM Pro+ 5-in-1 Color w/ Accsess
Michigan
Offline nincehelser
    • nincehelser.com
Re: Tower Sensor(06002m/592TXR) Humidity sensor replacment??
« Reply #1 on: November 15, 2017, 06:41:43 PM »
Tower sensors usually are made up of discrete components rather than a chip sensor like is in the 5n1.  I'm sure it's probably fixable.
I don't know if it would be cost and time effective, though, as a new tower sensor is about $13.
Offline daman
« Reply #2 on: November 15, 2017, 08:32:39 PM »
True, they are cheap.
Michigan
Offline DoctorKnow
« Reply #3 on: November 15, 2017, 09:39:49 PM »
Could there be moisture inside the sensor affecting the reading? I would open it up and see what's up. I found insects in mine one time.
Offline daman
« Reply #4 on: November 16, 2017, 07:45:32 AM »
It's inside my home monitoring temps in a room so moisture isn't a problem.
I was hoping the sensor could be replaced then I would have two but if not that's ok.
Michigan
