Author Topic: Windows 10 Bridging Issues  (Read 2112 times)
Offline ColoradoWeather
  • Acurite Model 010101
    • KCOFORTC64 - Hanna Farm
« on: September 01, 2017, 11:07:13 AM »
If you run into problems with bridging network connections in Windows 10... You are not alone. A very good workaround to run Kevin's software on a Windows 10 PC is to simply right click on the network connection that is connected to the Internet, select Properties from the popup menu and click on the Sharing Tab. Enable Internet Connection Sharing and everything will work great!
