Author Topic: list of cams what record at night for weather  (Read 2882 times)
Offline okieman98
  • new and learning
« on: August 28, 2017, 02:07:28 AM »
i saw a lot of weather cam on other folks weather sties,  that records night and day time trying to get a list of some good ones that are not 1000s of dollars thanks
PWS ID HEALDTON
Re: list of cams what record at night for weather
« Reply #1 on: August 28, 2017, 11:52:58 AM »
Stardot  (of course).  Starts around $500 on sale.  I also like my HD DLink 960L - about $140
Offline GregJ
    • http://www.SkunkBayWeather.com
« Reply #2 on: August 28, 2017, 01:06:30 PM »
I use the Canon Rebel T3 DSLR with IPTimelapse software for night photography only.  I get them on Ebay for around $300 used with low shutter count.  They do have a limited life span, so I use mine only on clear nights.  The quality is awesome though.  You can see some examples with my posts here.  Take a look at "Aurora All Night Long"....
Greg
Davis VP2 with VWS
"Everybody talks about the weather, but nobody does anything about it." -- Mark Twain
Offline okieman98
  • new and learning
« Reply #3 on: August 28, 2017, 01:26:07 PM »
ok thanks guys , will start checking the out.
PWS ID HEALDTON
Offline cospringswx
    • Colorado Springs Weather
« Reply #4 on: August 28, 2017, 02:10:53 PM »
Take a look at Hikvision. Below is the link to mine.
http://www.cospringsweather.com/Hikvision1.php
Ryan
Colorado Springs, CO
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline okieman98
  • new and learning
« Reply #5 on: August 28, 2017, 03:14:41 PM »
looks great like your site, that where i am trying to get to , have my own site. i may have some problem tho. ran across info on stardot and a few others about streaming. so i have checked my download and upload speed. since i am in a rural area i have the fasted that is here get 17megs download and only 2.2 upload, so not sure where to go from here without using all my band just for the cam, i have a small web cam i got a while back not as good as others but not sure what it will use, to live feed but may have to use a time lapse method any ideas
PWS ID HEALDTON
« Reply #6 on: August 28, 2017, 03:16:00 PM »
I stream my Satrdot with less bandwidth than you have.
Offline okieman98
  • new and learning
« Reply #7 on: August 28, 2017, 03:52:30 PM »
ok great , was sweating  that for a sec, i will start prepping
PWS ID HEALDTON
Offline WeatherHost
« Reply #8 on: August 28, 2017, 06:33:31 PM »
Bandwidth speed won't matter as much as a monthly bandwidth usage cap if your ISP imposes one.
Offline ValentineWeather
« Reply #9 on: August 29, 2017, 05:59:00 AM »
So are you streaming or just making a timelapse video? I have enough bandwidth to stream using Hikvision 264+ technology with 1.7 upload speed at 20-25 fps.
I prefer the hikvision's (best bang for $ cameras), the EXIR IR are best for night claiming 150' distance at night. Here is my online camera with stream if you want to check out best check at night this is a dark area with camera night settings at 80% gain so it could go brighter.
Link to stream allow up to a minute to connect its on demand and refresh a couple times will connect faster.
https://www.valentinenebraska.net/streamlive2.php
Camera is this model with 4mm lens.
https://www.amazon.com/gp/product/B01N4VZQ2M/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
For timelapse: https://www.valentinenebraska.net/jwsouth.php
Randy
Offline okieman98
  • new and learning
« Reply #10 on: August 29, 2017, 02:41:58 PM »
looks great, nice stream, will check it out tonight in night mode, i was looking on ebay and was looking at a ptz cam so i could turn it into the direction of a incoming storm front anyone use one of them and how do they do
PWS ID HEALDTON
Offline okieman98
  • new and learning
« Reply #11 on: August 30, 2017, 01:14:48 AM »
wow, looks good for a night shot, can really see far with that one, clear, going to look at the spec s and look at the ptz type and see what i can find before i order one, after looking around outside i could mount on the pole i am putting up to raise my station and could point it in any direction, i would like that for getting some good shots
PWS ID HEALDTON
Offline weatherc
« Reply #12 on: August 30, 2017, 05:14:26 AM »
RaspberryPI 3 + IR-CUT with 1 IR-LED installed, cost ca 50€  :lol:
https://www.nordicweather.net/webcam.php?en
« Reply #13 on: August 30, 2017, 06:31:05 AM »
One thing I've noticed about this camera the dreaded IR light spiderweb issues many smaller Hikvision models have I don't seem to have so far. The IR lights aren't surrounding lens like small cameras.
PTZ cameras may require additional power supply other than just POE just to let you know for camera motor movement so check specs closely and make sure it's not an issue if required.
Randy
Offline okieman98
  • new and learning
« Reply #14 on: August 31, 2017, 05:17:54 PM »
ok thanks good point, on the power to it, will do some more research, are u guys using the metro bridge to feed your web site. anyway all i have seen are made to mount with the dome down , not sure yet if i can get the elevation up with some of the ones yet not sure if they would hold up mounted dome up and if u would be able to rotate view and not be upside down researching what to choose lol  ](*,)
PWS ID HEALDTON
Offline bthoven
    • Europa Cafe' Private Observatory
« Reply #15 on: August 31, 2017, 08:22:04 PM »
A Chinese waterproof one here
« Last Edit: August 31, 2017, 08:26:34 PM by bthoven »
Offline okieman98
  • new and learning
« Reply #16 on: September 02, 2017, 06:26:36 PM »
humm is that looking straight up with it more of a fish eye view it looks like
PWS ID HEALDTON
Offline Michaelpt
    • Weather-Above.com
« Reply #17 on: September 02, 2017, 07:28:26 PM »
hi
the cam I use is very  cheap it a SONY ICX639BK CCD 600TV  LINES LOW ILLUMINATION
been running for some years
I put  a  heater mod inside the cam to stop any condensation, then used a
Stainless steel Dome as a  mirror
Web link of video. not good for  night time . I use a home  made sky ir temperature sensor for  night time  wd uses the date  for night cloud conditions
http://www.weather-above.com/video.html
my  favourite cam images  using meteotemplate
http://www.weather-above.com/meteotemplate/plugins/webcam/index.php
click on the calendar dates to see images and video
mick
« Last Edit: September 02, 2017, 07:32:43 PM by Michaelpt »
weather-above weather station consists of a  1 wire system ,sky ir cloud temperature ,UV,solar home made modules , live data seismic instrument there is  lot of information on modified sensors,  and 1wire projects pleased  sign my guestbook
Mmichael Parry-Thomas
http://www.weather-above.com/wxgraphic/wxgraphic.php
Offline waysta
« Reply #18 on: September 02, 2017, 08:32:56 PM »
There are a number of DIY wide angle cams based on ZWO astronomy cameras.  I think some have a wide enough range to tolerate sunlight, just learning about this approach.  ZWO recommends the ASI185MC ($329) color camera for use as a sky cam.
https://astronomy-imaging-camera.com/products/usb-3-0/asi185mc-color/
The models change so fast, you can often get an ASI type camera used for a lot less at the astronomy forums, such as cloudy night classifieds - https://www.cloudynights.com/classifieds/
Some folks replace the supplied wide angle lens with higher quality wide angle or fish eye lenses.
https://stargazerslounge.com/topic/280380-all-sky-camera-for-daytime-use/
https://stargazerslounge.com/topic/271844-ginas-diy-all-sky-camera-mark-4-with-zwo-asi185mc/
Here are some examples, many more by Googling ASI or ZWO and skycam.
http://www.instructables.com/id/Wireless-All-Sky-Camera/
https://stargazerslounge.com/topic/224699-my-home-built-asi-120mc-based-all-sky-camera/
https://www.youtube.com/watch?v=V8Nd5gZJabs
http://www.skyatnightmagazine.com/feature/how-guide/how-make-simple-all-sky-camera
« Last Edit: September 02, 2017, 08:49:04 PM by waysta »
Offline okieman98
  • new and learning
« Reply #19 on: September 02, 2017, 10:23:48 PM »
interesting approach for sure, i going to read the links, i am ordering a router for the metrobrige tonight so i can flash. fox to check to make sure it works on windows pc i sure it does tho
PWS ID HEALDTON
