Author Topic: WD UDB Data Logger  (Read 774 times)
Offline Scobey
    • Scobey's Weather
WD UDB Data Logger
« on: August 26, 2017, 11:26:38 PM »
What is the command WD uses to extract data from a Davis Pro2?
I think my WD is corrupted.
Offline waiukuweather
Re: WD UDB Data Logger
« Reply #1 on: August 27, 2017, 01:38:43 AM »
I think you mean a USB data logger?
why do you want to know the actual command?
what I would do is to reset the data logger
(power down console, remove the data logger, wait 5 minutes, put back, power up console, then set the time and date on the console and the data logging interval to 1 minute (using weatherlink or weather display)
Offline Scobey
    • Scobey's Weather
« Reply #2 on: August 27, 2017, 03:52:58 AM »
I have a brand new data logger. I have WD in the C:/ dir and in a f:/ dir.
The data logger works fine with c:/
Doesn't with F:/ What is the WD command that starts the data logging?
So it is software and I ask again.
« Reply #3 on: August 27, 2017, 03:59:28 AM »
it is the command that is specified in the vantage pro documentation (DMPAFT)
still not sure why you are wanting to know that
try copying the wdisplay.ini setting file from the c directory location to the f directory location
Offline Scobey
    • Scobey's Weather
« Reply #4 on: August 27, 2017, 04:00:52 AM »
OMG! Read my post.
Offline hankster
    • NFM Weather
« Reply #5 on: August 27, 2017, 10:27:00 AM »
Did you set up WD in the F:/ directory as a second install of WD? If not there could be conflicts in the registry.
« Reply #6 on: August 27, 2017, 02:42:24 PM »
OMG! Read my post.
I did
you wanted to know what is the command to extract the data logger
I provided you with that
not sure what more I can do
