Author Topic: Cumulus in lieu of Weather Link  (Read 2248 times)
Offline arrowspace90
  • Vantage Pro II, chimney mounted, 30' elevation
« on: July 26, 2017, 02:38:15 PM »
My friend has a new Vantage Vue with a Pro 2 console.  He has a Belfry Boy data logger.  Should that be adequate to hook up to Cumulus via a regular PC?
Will he need to download any additional drivers or anything else?
Is there anything else "special" that he might have to do, that is since he doesn't have Weather Link software?  Is WL essential??
Offline waiukuweather
Re: Cumulus in lieu of Weather Link
« Reply #1 on: July 26, 2017, 02:53:01 PM »
you will likely need a driver
but you can download e,g the silicon labs usb driver
there might also be a link to a suitable driver that comes with the data logger?
Offline mcrossley
    • Wilmslow Astro
« Reply #2 on: July 27, 2017, 03:35:06 AM »
I *think* the driver for the Belfry logger is built into windows. Cumulus has a "set logger" utility that you will need of you don't have WL - used to set the logging interval on the console.
« Reply #3 on: July 27, 2017, 10:40:39 AM »
Thanks guys.
So, the bottom line is, it "should" work, right?
I am telling my friend to CAREFULLY follow the Belfry Boy and Cumulus set up instructions.
Offline mcrossley
    • Wilmslow Astro
« Reply #4 on: July 27, 2017, 10:44:15 AM »
Yep, should work fine, and it's easy to move to a light weight 'puter later if he wants (eg raspberry pi) using the MX version.
Offline belfryboy
  • waiting for the rain.....
    • Belfryboy Blog
« Reply #5 on: July 29, 2017, 04:00:41 PM »
The drivers for the BelfryBoy logger are included with windows, but you would need to set the logging interval using a terminal program to ensure that the interval in Cumulus and the console match, or follow the instructions found here Logger setup utility.
It is important that the console time and logging interval are the same in the console and Cumulus, otherwise it can get a bit upset and lose communication.
