Author Topic: 8550RX failure  (Read 2196 times)
Offline eyecue
8550RX failure
« on: July 18, 2017, 03:33:33 PM »
Seems the speaker in my 8550RX has blown out.  Anyone else have this issue?  Accurite 8550RX.
Offline jimform2k1
Re: 8550RX failure
« Reply #1 on: July 22, 2017, 10:08:05 AM »
I have the same issue.  Someone posted this:
One thing.. the power level or  constant, piercing tone of the alert tone is blowing your little 1.5w coil based speakers. I thought my radio had died until I plugged headphones into it and found it was still doing its job. I figured it was an intermitting 1/8" jack bypass switch.. so I cleaned that out and resoldered it. No dice. Checked the 8ohm 1.5W speaker.. open.. hmm.. hooked up a headphone to the speaker terminals.. bingo. Bad speaker.
I replaced your design with a bit beefier 3w/8ohm 1.5" driver out of an old Rat Shack tape recorder. Works like a charm now.
Offline eyecue
Re: 8550RX failure
« Reply #2 on: July 22, 2017, 12:18:24 PM »
Thank you , that is what I had figured it was.
