Author Topic: Push Email Service with Meteobridge  (Read 1247 times)
Offline shirsch
« on: July 12, 2017, 07:51:26 PM »
I am trying to send push email service with my verizon email info and keep getting the following error message
Error: Failed to send email: msmtp: network read error: the operation timed out msmtp: could not send mail
Any help would  be appreciated
Steve
Offline docbee
  • Moderator
    • smartbedded
Re: Push Email Service with Meteobridge
« Reply #1 on: July 14, 2017, 05:41:04 PM »
Which smtp settings are you using? It is very likely that this setup is not correct.
« Reply #2 on: July 14, 2017, 07:02:17 PM »
Or a relay denial issue.  Some ISPs simply won't allow a redirected/third party email.  BTDT
Offline Dommer
« Reply #3 on: January 31, 2018, 07:41:06 AM »
Found this thread after spending a number of hours attempting to configure my Metobridge to send alerts to an e-mail address.
Would anyone happen to have a specific mail service and specific settings utilized to get this working?
I've tried gmail, yahoo mail and my web host mail (1&1) with no luck.  Error messages from Metobridge are not that clear.
Thanks in advance!
« Reply #4 on: January 31, 2018, 08:35:03 AM »
It works just fine with mine.  I am using the ISP settings (ie. smtp.nnnn.com with pwd etc/)  Do you have the right port for the security (SSL, TLS etc.)
Failing that, if you have a relay issue then get a free account at SMTP2Go.com  Works from everywhere - and I do mean EVERYWHERE.
Offline Dommer
« Reply #5 on: January 31, 2018, 10:37:19 AM »
Thanks for the quick reply, I'll take a look at smtp2go.
I tried every combination of ports/security settings with three mail providers with no luck.
Out of curiosity, which e-mail provider are you using?
Thanks again
« Reply #6 on: January 31, 2018, 03:01:30 PM »
I use Telus (Canada).  That works, as does Gmail and  another I use.  There must be something weird in your setup or your provider is blocking it.  SMTP2GO works behind firewalls, etc.  I use it when travelling internationally (in some pretty strange places, too) since I can't relay.
Offline LABob
« Reply #7 on: January 31, 2018, 11:39:09 PM »
I've had no issue using my 1&1 SMTP or Gmail SMTP. I think because I use SSL so the ISP doesn't block those ports.
Offline Dommer
« Reply #8 on: February 01, 2018, 03:35:11 PM »
Thanks Bushman, I was able to get this working with SMTP2Go!
LABob - good to know that it's working with GMAIL and 1&1, I must have had some incorrect settings, although I thought that I had tested all combinations, including SSL.
Offline LABob
« Reply #9 on: February 01, 2018, 03:43:03 PM »
Did you use port 587 and TLS for smtp.1and1.com?
Offline Dommer
« Reply #10 on: February 01, 2018, 04:02:41 PM »
I believe that I tried that combination, as I used settings as per 1&1:
https://help.1and1.com/e-mail-and-office-c37589/1and1-mail-basic-c37590/using-the-product-c85088/e-mail-software-setup-credentials-a616889.html
Will give it another try when I get home tonight.
« Reply #11 on: February 02, 2018, 01:21:44 AM »
Glad it worked. SMTP2GO is a great service.  I am slowly switching all my IoT devices to it (they are scattered all over North America)
Offline LABob
« Reply #12 on: February 02, 2018, 07:35:25 AM »
Make sure you're using the whole email address (user@domain.com) of the account you're sending from and the password for that account (not your 1&1 username and password).
