Author Topic: ASOS visit with VP2 in hand  (Read 13673 times)
Offline ValentineWeather
« on: July 08, 2017, 03:35:47 PM »
Visited ASOS today for comparison with my portable 24 hr. VP2 with SHT31 temp/humidity sensor. I collected 40 minutes of data but temperature wasn't changing much and unfortunately the 5 minute data from ASOS skipped most sections  ](*,) when there.... I took pictures of console every 5 minutes but will only provide the 2 times I received ASOS data.
The ASOS was reading +1F on one of the 5 minute intervals and the other time period both reported 91F. You can see the ASOS does read lower dewpoint /humidity as some that watch ASOS stations may have suspected.  -4° DP which ends up being 6% humidity in 90-91F range.
Anyway thought I would give what I found. What I would really like to do is several full days of side by side comparison but this sample told me some of what I suspected.
Randy
Re: ASOS visit with VP2 in hand
« Reply #1 on: July 08, 2017, 04:10:19 PM »
Somewhat surprised by this...granted a very small sampling though.
« Reply #2 on: July 08, 2017, 04:34:28 PM »
Really? Almost forgot that's why you always end up in QC jail.  :lol:
I wonder now if the issue you have isn't when DP/temp gets the big separation with sub 10% humidity.  I'm always about 4° higher on DP. But then again each ASOS may be different but they aren't suppose to be.  Remember the the debacle with the HO83 shield. I read somewhere recently they still haven't got all the bad HO83's out of field yet. https://wattsupwiththat.com/2008/01/10/inside-the-asos-ho83-tempdewpoint-sensor/
Randy
Offline WheatonRon
    • WUnderground
« Reply #3 on: July 08, 2017, 05:14:25 PM »
All I can say is, "very interesting" as used in the TV series, Laugh in, I believe! A portable VP2--must try that sometime! Maybe Davis is working on such a product--oops, sorry--I forgot that they are working on the VP3!
« Reply #4 on: July 08, 2017, 05:17:53 PM »
Only when the humidity gets below 2% does the 31's dew crash, otherwise it's completely comparable to my usual check points.
I think that the 31 has trouble way down low, just like about every sensor has problems way up high (asos's included).
« Reply #5 on: July 08, 2017, 05:28:29 PM »
I only took the shield, without anemometer or rain gauge but it could be easily attached. I would take a picture but it's all broke down and put away.
I clamp shield on 6' pipe that fits down in holder for dish. They call these non penetrating platform and looks just like this. You can weigh it down with cement blocks if needed.
Randy
« Reply #6 on: July 08, 2017, 05:32:38 PM »
 8-)
« Reply #7 on: July 08, 2017, 06:34:50 PM »
Some may remember my theory about in town with grass and trees being cooler during summer.
I just got back from airport 2nd time and can confirm anywhere from +2-4° warmer at airport with same matching Davis SHT-31's instruments I'm using in town. Amazing what grass and trees can do. The airport may be +1° warmer than SHT31 at times but taking accuracy of instruments into consideration it's within specs if Airport was + 1/2 degree and SHT31 - 1/2 degree.
I guess I can't complain ASOS is reading hot.
« Last Edit: July 08, 2017, 06:36:41 PM by ValentineWeather »
Randy
« Reply #8 on: July 08, 2017, 06:40:16 PM »
I'm quite sure that Central Park in NYC (just as one example) is several degrees cooler than the surrounding area.
« Reply #9 on: July 08, 2017, 06:53:21 PM »
I'm sure it is.
I guess the issue that pushed me into checking this for myself is my neighbor telling me why was the airport 97° and you are only 93°. My thermometer under house eve was also 97° today.  :?: When I try to explain it's because your thermometer is against the house in a heat pocket the response is well it's the same as airport.  ](*,)
Randy
« Reply #10 on: July 08, 2017, 07:09:21 PM »
Many just don't get it, nor care to.
Offline openvista
    • marquetteweather.com
« Reply #11 on: July 08, 2017, 07:32:39 PM »
Interesting! I also noticed that the pressure readings were very close. Did you adjust the elevation or did it just happen to work out? Since the VP2 console doesn't do altimeter and it was so warm, I would have expected there to be an appreciable difference between the two readings (MSLP vs QNH).
« Reply #12 on: July 08, 2017, 07:39:07 PM »
The altimeter I just used the zero elevation method and matched airport. I haven't touched pressure on the VP2 console for years but it's still very close.  I use the VUE console as my primary unit because it does have altimeter and usually dead on.
Randy
« Reply #13 on: July 08, 2017, 08:00:30 PM »
This works well for the VP2 console in lieu of not having a Vue for the actual altimeter. As long as you're not in quite relatively high or low pressure, the VP2 is very close.
« Reply #14 on: July 08, 2017, 08:34:39 PM »
Well, you were a couple hundred feet away. Micro climate?
Just sayin.
« Reply #15 on: July 08, 2017, 08:35:53 PM »
Just sayin.
 :oops:
Randy
« Reply #16 on: July 08, 2017, 08:44:43 PM »
Just sayin.
The only micro-climate (and think this term is pushing it here) that could apply at this short distance would be wind velocity/direction at any given moment and rainfall. Temp and humidity should be virtually identical.
« Reply #17 on: July 08, 2017, 08:48:48 PM »
I took it as a joke. We had a nice steady breeze so I'm pretty sure it was representative of conditions 100 yards away.  8-)
Its also flat as a pancake .....
Randy
« Reply #18 on: July 08, 2017, 09:01:13 PM »
Oh....yeah. I get too wrapped up in this stuff sometimes. :oops:
« Reply #19 on: July 08, 2017, 09:30:37 PM »
I forgive you  :-)
Randy
Offline WheatonRon
    • WUnderground
« Reply #20 on: July 08, 2017, 11:33:07 PM »
I forgive you  :-)
You shouldn't forgive a Penguins fan!
Offline alexstaar
« Reply #21 on: July 09, 2017, 12:50:03 AM »
Also bear in mind that if your station is set up in a locale with more vegetation (i.e. trees, shrubs, irrigated grass, etc.) such as a neighborhood/subdivision than at an open and exposed location like an airport/airfield, you will have a lot more transpiration of water vapor from the vegetation leading to locally higher vapor pressure, relative humidity, dewpoint, etc. With this considered, air with a higher water vapor content heats less efficiently than air with lower water vapor content. So there may very well be discrepancies this manner as well.
-Alex
Davis 6153 VP2 with 24-hour FARS/
Davis 6250 Vantage Vue
WU: KNJMOUNT68/KSCGREER81
CWOP: FW5135/EW6390
www.uah-mcthornmoracres-weather.com
« Reply #22 on: July 09, 2017, 01:31:02 AM »
Absolutely I'm located on a very densely vegetated side of town including a creek nearby.
Randy
« Reply #23 on: July 09, 2017, 02:04:33 PM »
Ran across tripod I had stored away. This is a better way of mounting VP2 shield on pvc pipe and using tent stakes for stability in wind.
Randy
« Reply #24 on: July 09, 2017, 03:59:40 PM »
Very hot day set a station record 106°. Took the portable back out to airport and matching 108° at 240pm. Didn't stay long it was too HOT!
« Last Edit: July 09, 2017, 05:12:01 PM by ValentineWeather »
Randy
