Author Topic: Tropical Storm Beatriz ( ...DEPRESSION BECOMES TROPICAL STORM BEATRIZ JUST SOUTH  (Read 1395 times)
A TROPICAL STORM WARNING IS IN EFFECT FOR...
* THE PACIFIC COAST OF MEXICO FROM SALINA CRUZ TO PUERTO ESCONDIDO
A TROPICAL STORM WARNING MEANS THAT TROPICAL STORM CONDITIONS ARE
EXPECTED SOMEWHERE WITHIN THE WARNING AREA...IN THIS CASE WITHIN
THE NEXT 12 HOURS.
TROPICAL DEPRESSION CENTER LOCATED NEAR 15.4N  97.1W AT 01/1500Z
POSITION ACCURATE WITHIN  30 NM
PRESENT MOVEMENT TOWARD THE NORTH-NORTHEAST OR  20 DEGREES AT   5 KT
ESTIMATED MINIMUM CENTRAL PRESSURE 1005 MB
MAX SUSTAINED WINDS  30 KT WITH GUSTS TO  40 KT.
WINDS AND SEAS VARY GREATLY IN EACH QUADRANT.  RADII IN NAUTICAL
MILES ARE THE LARGEST RADII EXPECTED ANYWHERE IN THAT QUADRANT.
REPEAT...CENTER LOCATED NEAR 15.4N  97.1W AT 01/1500Z
AT 01/1200Z CENTER WAS LOCATED NEAR 15.2N  97.2W
FORECAST VALID 02/0000Z 16.0N  96.7W...INLAND
MAX WIND  25 KT...GUSTS  35 KT.
FORECAST VALID 02/1200Z 16.9N  96.2W...POST-TROP/REMNT LOW
MAX WIND  20 KT...GUSTS  30 KT.
FORECAST VALID 03/0000Z...DISSIPATED
REQUEST FOR 3 HOURLY SHIP REPORTS WITHIN 300 MILES OF 15.4N  97.1W
...DEPRESSION BECOMES TROPICAL STORM BEATRIZ JUST SOUTH OF THE
COAST OF MEXICO...
SUMMARY OF 100 PM CDT...1800 UTC...INFORMATION
LOCATION...15.4N 97.0W
ABOUT 40 MI...65 KM WSW OF PUERTO ANGEL MEXICO
ABOUT 220 MI...355 KM ESE OF ACAPULCO MEXICO
MAXIMUM SUSTAINED WINDS...45 MPH...70 KM/H
PRESENT MOVEMENT...NNE OR 20 DEGREES AT 6 MPH...9 KM/H
MINIMUM CENTRAL PRESSURE...1004 MB...29.65 INCHES
DISCUSSION AND 48-HOUR OUTLOOK
At 100 PM CDT (1800 UTC), the center of Tropical Storm Beatriz
was located near latitude 15.4 North, longitude 97.0 West.
Beatriz is moving generally toward the north-northeast near 6 mph
(9 km/h) and this motion is expected to continue through Friday.  On
the forecast track, the center of the tropical cyclone is expected
to move inland across the state of Oaxaca later today or tonight.
Recent satellite wind data indicate that maximum sustained winds are
now near 45 mph (70 km/h) with higher gusts.  Little change in
strength is likely before landfall.  After landfall, Beatriz is
expected to weaken and dissipate on Friday over the mountains of
southeastern Mexico.
Tropical-storm force winds extend outward up to 35 miles (55 km)
from the center.
The estimated minimum central pressure is 1004 mb (29.65 inches).
HAZARDS AFFECTING LAND
RAINFALL: Beatriz is expected to produce total rainfall
accumulations of 8 to 12 inches across the Mexican state of Oaxaca
with isolated maximum totals of 20 inches possible.  Lighter
amounts in the 1 to 3 inch range are possible across the southern
portion of the Mexican state of Veracruz.  This rainfall is likely
to produce life-threatening flash floods and mudslides.
WIND:  Tropical storm conditions are expected within the warning
area during the next several hours.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
I think it might be useful if you at least added some comment rather then just re-posting articles from elsewhere... ;) Should I start copying Czech forecasts here? I mean its fine to discuss things, but if you just copy/paste it is not of much use, not to mention that there are millions of things that could be copied here.
