Author Topic: WilmingtonWX USPLN Lightning Purchase Not Received  (Read 1670 times)
Offline Kurtb
  • Trained Weather Spotter, and CoCoRaHS member
    • Space Coast Weather
« on: May 19, 2017, 11:16:08 AM »
I spent $50 on this 28 hrs ago (as of 11 AM EST or 1500 Z) and everytime I try I go to http://wilmingtonwx.com/customize.php?product=lightning and enter my ID I receive the following.
"Unrecognized user ID.
You are seeing this page because no records were found corresponding to the provided ID. This may be because you have incorrectly copied your ID or you are not a subscriber of this feed. If you have just made your purchase, check back soon and if the problem persists, contact admin@wilmingtonwx.com with details."
I'm curious if I'm doing something wrong, or what. Any advice is highly appreciated. Thanks!
Offline sacreyweather
  • Echo Valley Weather
Re: WilmingtonWX USPLN Lightning Purchase Not Received
« Reply #1 on: May 19, 2017, 11:23:03 AM »
Have you emailed them? Do you have access to the GRLevelX Forums? If so, he has an extensive topic listing there under the "Placefiles" sub forum.
Hope this helps,
Saline Weather on Twitter
Blitzortung Station 1387
Offline Kurtb
« Reply #2 on: May 19, 2017, 11:26:42 AM »
I have emailed, but I'll try that when I have time. I am not on GRLevelX forums, but I'll try that in a few.
