Author Topic: Heads-up for GR2Analyst user in Chanhassen, MN (lat=44.849,lon=-93.565)  (Read 1233 times)
Online saratogaWX
You seem to have the incorrect URL for the USA regional member's conditions placefile in your settings.. I see 404-Not Found records like
2601:444:4180:ce:8d46:505e:e89c:958 - - [17/May/2017:00:20:07 -0400] "GET /mem%20...%20cefile.txt?&version=1.3&lat=44.849&lon=-93.565 HTTP/1.1" 404 - www.northamericanweather.net "-" "GR2Analyst" "-"
2601:444:4180:ce:8d46:505e:e89c:958 - - [17/May/2017:00:21:08 -0400] "GET /mem%20...%20cefile.txt?&version=1.3&lat=44.849&lon=-93.565 HTTP/1.1" 404 - www.northamericanweather.net "-" "GR2Analyst" "-"
2601:444:4180:ce:8d46:505e:e89c:958 - - [17/May/2017:00:22:08 -0400] "GET /mem%20...%20cefile.txt?&version=1.3&lat=44.849&lon=-93.565 HTTP/1.1" 404 - www.northamericanweather.net "-" "GR2Analyst" "-"
You should correct the URL for the placefile in your GR2Analyst to be
http://northamericanweather.net/members-placefile.txt
and then it will work fine :)
    • Robbinsdale Middle School Weather
its not me! don't have GR2.
Vantage Pro Plus 6163
Offline WeatherHost
Public exposure of personal information is exactly why I don't participate in most programs.
Banners, tags, widgets, etc. are why I have Signatures turned off.
Online saratogaWX
I'm not sure what you are meaning by 'programs'...
All websites accumulate access logs, and the access logs (sample in my post) have IP addresses (either IPV4 or IPV6) and there are multiple geo-ip location sites/utilities and good-ol' whois to show info relating to the IP address.
I don't think that IP addresses fall under the 'personal information' category as you don't 'own' it, only use one supplied by the ISP (who 'owns' the address space).
I only post access_log contents when I find someone/thing using site resources ineffectively (like the bad URL for the member-placefile above).  The public posting is just an alert that may be seen by the person using it and can get it corrected (hopefully).   The 404 doesn't cause any issues for my server.. just another cast-off access with low overhead.
Offline dupreezd
I apologize if it seems if I revealed personal information.  I removed the posting.
This only shows that the user is using Comcast as it provider and from where Comcast distribute it service from.
« Last Edit: May 18, 2017, 07:09:35 PM by dupreezd »
WS-1200-IP | ObserverIP | Meteobridge
WU, PWSWeather - KTXCONRO61
CWOP - FW0717
Blitzortung 2100
