Author Topic: AWOS3P coding for local airport on FAA website  (Read 2282 times)
Online miraculon
« on: April 26, 2017, 08:32:23 AM »
I regularly check the local airport weather station either by the web or via the 118.125MHz signal.
I was wondering what it takes to have precipitation added to this station. According to the info at AirNav, it is an ASOS-3. According to the FAA, it is an ASOS3P implying that it should include precipitation. It does have a precipitation type sensor, but no amounts. See https://www.faa.gov/air_traffic/weather/asos/?airportId=KPZQ Does the precipitation type give it the "P" suffix?
I see other info indicating that ASOS stations have the precipitation gauges (older was heated TBR, now weighing).
Are precipitation gauges uncommon for these stations?
Re: AWOS3P coding for local airport on FAA website
« Reply #1 on: April 26, 2017, 08:46:34 AM »
Doesn't look like it has an operating rain gauge. If you check yearly data it says not available.
http://www.wrh.noaa.gov/mesowest/timeseries.php?wfo=twc&sid=KPZQ&num=48
Your CWOP station:
http://www.wrh.noaa.gov/mesowest/timeseries.php?wfo=twc&sid=C4114&num=48
« Reply #2 on: April 26, 2017, 09:31:21 AM »
MesoWest verifies station doesn't have any rain gauge. Toward bottom are station sensors, not sure why.
http://mesowest.utah.edu/cgi-bin/droman/station_total.cgi?stn=KPZQ&unit=0
