Author Topic: APRS Utility Location settings  (Read 566 times)
Offline ch8ch
  • ***ch8ch***
« on: April 15, 2017, 08:49:52 AM »
Settings ask for Degrees and minutes (LAT/LON)
Entered said values.....
Wrong location showing on map
Offline Cutty Sark Sailor
Re: APRS Utility Location settings
« Reply #1 on: April 15, 2017, 09:46:37 AM »
VWS and CWOP location should be something like
41.5309147
-75.5454634
VWSaprs settings should be something like
North 41 degrees 31.85 minutes
West 75 degrees 32.73 minutes.
http://www.directionsmag.com/site/latlong-converter/
Also helps if you provide more info in your questions, things like location, CWOP station number, etc.. I just assume you're somewhere around East Jermyn PA...
« Last Edit: April 15, 2017, 09:48:25 AM by Cutty Sark Sailor »
CoCoRaHS KY-FR-1  CWOP DW5536
       Blitzortung
     689 791 1439
sferics.us
NWROrg
Offline ch8ch
  • ***ch8ch***
« Reply #2 on: April 15, 2017, 11:32:48 AM »
VWSaprs is the correct info I just couldn't get right.
Thank you very much and CWOP is EW8531
East Jermyn PA.
Thanks for the converter!
« Last Edit: April 15, 2017, 11:38:09 AM by ch8ch »
