Author Topic: wxspace  (Read 1414 times)
Offline n7xrd
    • Beachhouse Weather
wxspace
« on: March 31, 2017, 09:38:58 AM »
I'm having a problem with the loading of my wxspace page it is inconsistent sometimes it works most times not. different things don't always load mostly the Error reading spaceweather current update data. I do have the cache file set to 777.
http://www.beachhouseweather.com/wxspace.php
Offline W3DRM
    • Carson Valley Weather
Re: wxspace
« Reply #1 on: April 01, 2017, 12:38:51 PM »
Steve,
I occasionally have one or more images not show up too but mine seems to work fine otherwise. Take a look at my version of wxspace. I made some changes to it and can post it here if you want to play with it. The link to my webpage follows:
Davis Wireless VP2, WD 10.37s85,
--- RIPE Atlas Probe - 32849
Offline n7xrd
Re: wxspace
« Reply #2 on: April 01, 2017, 12:51:02 PM »
Steve,
I'm wondering if the issue is something on my end your site has about the same as mine that don't load every time if I refresh a few times I can get most all to work!!
Offline W3DRM
Re: wxspace
« Reply #3 on: April 01, 2017, 12:59:29 PM »
I notice that both of our wxspace routines seem to take quite a while to fully load (as much as 10-15 seconds). Am wondering if it is a server issue and not something with our code. Mine shows "Error 018" on some of the solar images and yours is showing "Error 019" on the LASCO Solar Corona. I don't know what those two errors mean.
Offline n7xrd
Re: wxspace
« Reply #4 on: April 01, 2017, 01:01:04 PM »
I've been told it could be my host Godaddy not sure why though?
Offline W3DRM
Re: wxspace
« Reply #5 on: April 01, 2017, 01:07:16 PM »
Possibly, but I am using 1and1.com and am having similar issues. I wonder if others are also having problems? I just checked Ken's on Saratoga-Weather and his space page loads almost instantly and all images look good. Am wondering if I have something wrong in my code. Will review it later today.
Offline n7xrd
Re: wxspace
« Reply #6 on: April 01, 2017, 01:09:24 PM »
I'm using Ken's version 1.5 so not sure if he has something different on his site or not!!  ??
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
Re: wxspace
« Reply #7 on: April 01, 2017, 01:31:56 PM »
Mine seems to work fine on 1and1
https://www.northbendweather.com/wxspace.php
Software: WeatherDisplay
Hardware: Davis VP2 + VP2 Solar + VP2 UV + Lightning Detector + Logitech Webcam
Offline n7xrd
Re: wxspace
« Reply #8 on: April 01, 2017, 03:54:18 PM »
Most of it did 1 error 005 on one picture
Re: wxspace
« Reply #9 on: April 01, 2017, 07:20:34 PM »
I had experienced some 500-Errors while trying to load all the images via the PHP scripts each time the space-weather.php page was loaded.  I decided to modify the image URLs to load the cache files in the page, and then append
# Pull the images for space-weather.php by cron
cd $HOME/httpdocs/wx
echo "$(date +%Y-%m-%d_%H:%M:%S) start images load" > image-space-status.txt
/usr/bin/php -q image-space-aurora.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-cycle.php >> image-space-status.txt
/usr/bin/php -q image-space-aurora-s.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-disk.php  >> image-space-status.txt
/usr/bin/php -q image-space-eit-284.php  >> image-space-status.txt
/usr/bin/php -q image-space-solargraph.php >> image-space-status.txt
/usr/bin/php -q image-space-eit-304.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-number.php >> image-space-status.txt
/usr/bin/php -q image-space-sat-env.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-radio.php >> image-space-status.txt
/usr/bin/php -q image-space-solar101vhf.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-ap.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-wind.php >> image-space-status.txt
/usr/bin/php -q image-space-solar-corona.php >> image-space-status.txt
/usr/bin/php -q image-space-xray.php >> image-space-status.txt
echo "$(date +%Y-%m-%d_%H:%M:%S) finished images load" >> image-space-status.txt
to a cron job that was already running every 5 minutes to redraw my sparkline graphs on the almanac page.
That's why my page loads fast .. it only gets the text forecast from the site and then uses the cached images preloaded by the cron job.
Since I'm on my own VPS, I have to do some efficiency things to minimize the PHP loads, even running PHP 7.1 :)
Offline n7xrd
Re: wxspace
« Reply #10 on: April 01, 2017, 09:50:09 PM »
Seems mine even has trouble loading the text forecast also!
Offline uncle_bob
    • Conder Weather
Re: wxspace
« Reply #11 on: April 07, 2019, 03:31:11 AM »
Hi Guys,
Does anyone know where we can get an updated wxspace script? Mine seems borken and simply changing the http prefix to https doesn't seem to unbork it.
Re: wxspace
« Reply #12 on: April 07, 2019, 10:55:58 AM »
Offline uncle_bob
    • Conder Weather
Re: wxspace
« Reply #13 on: April 08, 2019, 07:52:24 AM »
Thanks Ken!
