Author Topic: V14p56 Comm Port Issue [CLOSED]  (Read 3059 times)
blackjack52
  • Guest
« on: January 29, 2009, 04:13:44 PM »
Installed p56 ok, and ENT Comm 4 when it asked me for the Comm Port.  Restarted, and all data populated, but Comm Port showed 1.  Tried changing again, Restarted, NOGO.  I fell back to my known stable p50 for fear Conflicts would start.
Also, MESONET D/L were hit/.miss.  And when it showed there was a d/l of meso data, the map and table were blank.
« Last Edit: February 08, 2009, 02:58:52 PM by MadALwx »
Offline svcrews
    • Southeastern Kentucky Weather
Re: V14p56 Comm Port Issue
« Reply #1 on: January 29, 2009, 10:23:06 PM »
Not sure if this will help, but I happen to be sitting in front of the comptuer when p55 came out, same problem, so I wrote Ed.  He quickly responeded and advised the below, while he fixed the problem, it worked,then minutes later p56 came out, and all was well again.
From: AmbientWeather.com [mailto:support@ambientweather.com]
Sent: Wednesday, January 28, 2009 5:04 PM
To: svcrews@mindspring.com
Subject: Re: VWS p55
I will fix this.
In the mean time:
1. Stop VWS
2. Delete the file c:\vws\setup\config6.bin
3 Restart VWS
4. Enter serial data logger
Ed
Offline kray1000
  • Purveyor of wry
« Reply #2 on: January 30, 2009, 08:19:46 AM »
I'm still running 14.00p18, and some of my mesonet downloads were a little slow yesterday ("error downloading file").  May or may not have been the software.
blackjack52
  • Guest
« Reply #3 on: January 30, 2009, 09:30:51 AM »
Thanks svcrews and kray.  I'll try the bin thing, but want to know if there are addt'l setup items in that bin.
blackjack52
  • Guest
« Reply #4 on: January 30, 2009, 09:47:53 AM »
This was found and fixed in P57.
Offline svcrews
« Reply #5 on: January 30, 2009, 09:49:36 AM »
After the config6.bin was deleted, and VWS came up, a screen came up to re-enter the comm settings.  I re-entered that info, looked though everything else, all was good, no problems, and that was p55, everything else was transparent to p.56.
Hope this helps.
Steve
