Author Topic: getting cvs files  (Read 1327 times)
Offline okieman98
  • new and learning
getting cvs files
« on: March 17, 2017, 04:10:15 PM »
after playing around with the software found directions got it up and running on the new smart hubs. need some direction on how to get the cvs file ,i think that weather display needs to look at for it to work and where to save thank for great software
PWS ID HEALDTON
Offline WonderWX
Re: getting cvs files
« Reply #1 on: March 17, 2017, 04:53:28 PM »
in the Settings menu, click the box for "Write to CSV File"  and then specify a File path and filename for it to save to
Offline okieman98
  • new and learning
« Reply #2 on: March 17, 2017, 04:55:57 PM »
ok will give it a shot thanks
PWS ID HEALDTON
Offline okieman98
  • new and learning
« Reply #3 on: March 20, 2017, 04:13:02 PM »
i know this is basic stuff to most of yall, from what i have been reading on the form and i have learned alot so far , just got me hooked more. but writing pathways for me is above my head a little, can someone show a example of how to do this, it may help others to that are still learning. thanks
PWS ID HEALDTON
Offline WonderWX
« Reply #4 on: March 20, 2017, 05:11:58 PM »
As example, if you run Kevin's program from the directory c:\bridge
To have the program output the file into this directory, you could put c:\bridge\myweather.csv
into the settings screen
« Last Edit: March 20, 2017, 06:08:51 PM by WonderWX »
Offline okieman98
  • new and learning
« Reply #5 on: March 20, 2017, 05:52:58 PM »
thank u so much that will help me out a lot
PWS ID HEALDTON
Offline ColoradoWeather
  • Acurite Model 010101
    • KCOFORTC64 - Hanna Farm
« Reply #6 on: March 20, 2017, 08:28:13 PM »
Sorry okieman98, I have been missing in action lately. I did get your private message. I will answer any questions you have here on the open forum as it might benefit others as well. Sounds like you have made some great progress!
Jack
Offline okieman98
  • new and learning
« Reply #7 on: March 21, 2017, 01:29:49 AM »
thanks jack , the only reason i sent it that way was kinda ashamed  :oops:   i did not know the basic stuff like that, but learning quickly u guys are so advanced and really know your stuff fro a new guy yall kinda talk above our  heads but thats understandable. we have to catch up. and ask those stupid question yall may have talked about many times. but anyway i am impressed with what the software has to offer. i have weather display working now but not real happy with it because the display is small in one corner and have not been able to make it full screen to read everything.is there any more software i can use to read the cvs data that is better then what i have got. trying to take it one step at a time so i can make sure i know how it works, have a starter cam coming and i want to connect to nws to up load data. which i will start on tomorrow
thanks again jeff
PWS ID HEALDTON
