Author Topic: reset rainwise sensor array Winf g direction not accurate  (Read 1287 times)
Offline wfollet@gmail.com
« on: March 08, 2017, 01:35:36 PM »
My rainwise anemometer was replaced due to damage and since then the wind direction sensor has been off by 180 degrees.  Everything I do doesn't make a difference.  The Maine people say it is precalibrated so I shouldn't have to do anything.
Offline VaJim
Re: reset rainwise sensor array Winf g direction not accurate
« Reply #1 on: March 09, 2017, 11:33:42 AM »
180 degrees..?
Sounds like it may not be installed properly.
Is this a replacement part to a MKIII..??
« Reply #2 on: March 09, 2017, 02:32:37 PM »
Yes straight from Maine I put it on exactly how it came.  Plugged it in and put the groove on the set screw.
« Last Edit: March 09, 2017, 02:34:55 PM by wfollet@gmail.com »
Offline VaJim
« Reply #3 on: March 09, 2017, 02:43:39 PM »
I'd call Rainwise and let them walk you through it.
The only other thing I can think of was that somehow your whole assembly (solar panel) got shifted around.
Also, try a re-set on the assembly unit (power off/ power on).  You may need to leave it off until your display in the house sees dashes.
Good luck.
« Reply #4 on: March 10, 2017, 07:25:01 AM »
Thank You
