Author Topic: WEATHER34 TEMPLATE with meteobridge options  (Read 25146 times)
Offline webcam
    • Wetterstation Brienz
Re: HOMEWEATHERSTATION TEMPLATE with meteobridge options
« Reply #175 on: December 06, 2017, 01:05:54 PM »
Hey super, merci for the tutorial ...
Greeting
Daniel
Offline rob3r7o
« Reply #176 on: December 07, 2017, 10:02:09 AM »
just for information but the wind speed in knots has been removed or am I something wrong?
I had it before, not now.
Thank you
Offline webcam
« Reply #177 on: January 05, 2018, 01:22:21 PM »
Hello everybody,
I do not agree with the position of the graphics.
Have instlliert the newest version.
Offline webcam
« Reply #178 on: January 10, 2018, 12:25:21 AM »
Funny, have uploaded an older version again and there is the position of the graphics.
Offline Glock43
« Reply #179 on: January 18, 2018, 02:58:07 AM »
Thank you weatherist34 for sharing your software! It displays everything I'm interested in in a well thought out, intuitive, & attractive way.
I wanted to point out a typo I found in the documentation. The folder name is misspelled and it's easy to miss if you are just copying & pasting like I did. Thanks again!
-John
Offline Glock43
« Reply #180 on: January 18, 2018, 03:06:24 AM »
I replaced the "forecast" Folder and "solar2.php" File with the latest versions and that solved my problems with forecasts from WU and the UV/Solar graphic problem. (mine looked like yours)
Offline webcam
« Reply #181 on: January 18, 2018, 03:44:13 AM »
ok, graphics are right again.
But something is not right downstairs. The whole flashes with me.
https://www.wetterbrienz.ch/pws/
Offline webcam
« Reply #182 on: January 19, 2018, 05:00:24 AM »
Ok, I reinstalled everything. Now it is ok
Offline Guillermo Villan
  • Ing. Eléctrical
    • WXElortondo - Estación Meteorológica Automática de Elortondo
« Reply #183 on: May 09, 2018, 06:46:50 PM »
People I can not make the date where the time is. In the configuration in "show updated date & time" there is only the option of false. I am using the cumulus template.
my site is www.wxelortondo.com.ar
Thank you very much.
William
Offline weather34
  • its just my hobby
    • Weather34 meteobridge template
« Reply #184 on: May 10, 2018, 01:49:24 AM »
good morning
the update time is the time your realtime.txt was written on your server .
try cumulus forum ..http://sandaysoft.com/forum/index.php
Offline EAF90
« Reply #185 on: June 27, 2018, 12:53:11 AM »
Hi!
I'm trying to make my website work but I can't, it only shows a blank page in the index.php.
Meteobridge is working and sending data, MBrealtimeupload.txt is working, and I think the DB is working too. File permissions are ok.
easyweathersetup.php works, but when I go to the website, it shows a blank page  ](*,)
What can I do?!  #-o
Offline weather34
  • its just my hobby
« Reply #186 on: June 27, 2018, 04:36:34 AM »
Hi!
What can I do?!  #-o
hello
need some basic info like url impossible to make any diagnosis..
could be php configuration where certain functions are disabled .
also provide the url and easyweathersetup password by a pm you can change the password at anytime.
brian
Offline mav101
« Reply #187 on: July 10, 2018, 09:40:45 AM »
I've just setup the latest template (meteobridge) after running a really old version for a while.... and I'm having a problem with the darksky current conditions and forecast. I have entered the API key correctly. I have checked the jsondata folder and it doesn't appear to have downloaded any new darksky.txt file (or any of the other files for that matter - i did also setup the metar along with the api key to test if it worked) its still using the data file from the template zip. Is there something else that needs to be setup to allow the connection to darksky?
Also, no calls appear to have been made to DarkSky according the the darksky api console...
Cheers, Andy
« Last Edit: July 10, 2018, 10:46:14 AM by mav101 »
Offline weather34
  • its just my hobby
« Reply #188 on: July 10, 2018, 10:32:02 AM »
good afternoon
please always provide a url if possible , its nigh on impossible to diagnose anything without.
most common cause is services not setup in meteobridge . have a read especially part 2 . https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
the stationcron.php file contains all the scripts to collect data from API services .meteobridge allows you to simulate cron jobs just by doing below.hope it helps
i can test it remotely but url is required
Part 2 . Setting up the services .
1.select services tab
2.goto new and select service from the drop down and choose HTTP REQUEST
3.goto select event type and choose PERIODICALLY
4.set the stationcron.php url to run every 15 minutes
examples of the url path to the stationcron.php
example 1 : http://yourdomain/mbdbfiles/stationcron.php
example 2 : http://yourdomain/pws/mbdbfiles/stationcron.php
example 3 : http://yourdomain/mbridge/mbdbfiles/stationcron.php
brian ...have a nice day
Offline mav101
« Reply #189 on: July 10, 2018, 01:04:44 PM »
Brilliant, thanks Brian.  I had missed that part of the instructions as i thought it was all about the mySQL setup... that's on the todo list ;-)   All working nicely now  :grin:
Cheers, Andy
Offline jkozik
« Reply #190 on: August 14, 2018, 11:53:38 AM »
I fixed my blank screen problem.
Just like the problem that @EAF90 reported above:  I too created a pws directory on my linux server. Running easyweathersetup.php works fine, and the permissions look ok. But mywebpage.com/pws/index.php returns a blank page.  I looked inside of the page source and the browser console -- nothing, blank.
I looked up how to debug php scripts, turned on error messages and started individually running each of the php scripts inside of index.php.  For the script called common.php, it returned: "PHP Fatal error:  Uncaught Error: Call to undefined function mb_internal_encoding()"  Huh?  I have never heard of this.
I looked it up and my Centos 7 default php installation does not include support for multi-byte strings.  That's a new one for me!  I updated my php:
# yum install php-mbstring
I restarted my httpd and now my index.php runs without error, no more blank screen.
Offline kweaver66
  • Kevin Weaver
    • Weaver Estates Wx-Watch
« Reply #191 on: August 18, 2018, 09:23:55 AM »
Brian,
Do you think you can check out my page?  I will DM you my PW if needed.  I know you said their were some issues with Metar and Darksky for some.  I cannot get my page to read either. It defaults to LTBA Istanbul.....
http://weaverestates.info/PWS/
Offline weather34
  • its just my hobby
« Reply #192 on: August 18, 2018, 10:04:46 AM »
replied via PM..
Offline kweaver66
  • Kevin Weaver
« Reply #193 on: August 19, 2018, 12:00:15 AM »
Thanks! back up and running!
Offline Atlantic21
    • Ilfracombe Weather
« Reply #194 on: August 19, 2018, 06:04:25 AM »
Could some one please help with the following warning on main page see attachment or link to web site
https://www.ilfracombeweather.info/pws/index.php
works fine on mobile or tablet
Richard
Offline weather34
  • its just my hobby
« Reply #195 on: August 19, 2018, 08:20:03 AM »
pm sent possible solution with file i sent . i tried replicating locally but no errors so I'm going to have to guess on it .
brian
Offline Atlantic21
« Reply #196 on: August 19, 2018, 09:44:36 AM »
Brian that worked many thanks again for help
Richard
Offline weather34
  • its just my hobby
« Reply #197 on: August 24, 2018, 08:02:21 AM »
Hello
spent a lot of time(almost 3 months)  finally getting round to finish of the re writing of the light theme . lots of minor visual tweaks and removal of unwanted code and css ,listened to requests and tried to improve in areas where I could without creating something totally different.
hope it is to your liking and keeps almost in the simple visual display of station hardware data . by far the meteobridge is the most popular choice and this version tries to get the most out of the flexibility of meteobridge options in terms of data.
if there is anything specific data value that you would like you can always drop an email and I can request Boris to add it onto the api .I understand everyone has different requirements and due to the simplicity of using meteobridge it is not inconvenient to have any extra data added on and most of it can be done within a reasonable timely manner.
it also is identical to use with the new meteobridge NANO product simply no changes to use template required.
anyway has always https://weather34.com/homeweatherstation/
« Last Edit: August 24, 2018, 08:04:23 AM by weather34 »
Offline leliep
« Reply #198 on: November 03, 2018, 05:42:36 AM »
I just became member of this forum, but I'm not able to access https://weather34.com/homeweatherstation/
When I try to open that link, I get an
Forbidden
You don't have permission to access /homeweatherstation/ on this server.
Do I need to be allowed to access the stuff or is there some kind of problem with the website?
Thanks & best regards, -pl
Offline weather34
  • its just my hobby
« Reply #199 on: November 03, 2018, 06:51:08 AM »
Forbidden
hello welcome
unfortunately its not me or anything personal its my host blocks certain ip ranges automatically
either drop a pm or use the direct link bypassing the homepage
http://www.mediafire.com/file/2w843u8d2df96sw/MB.zip
i guess its a good time to highlight some of the changes to the template .
1.Davis forecast text now displayable
2.improved browser styled charts (highly recommend switch to MYSQL)
3.Windspeed module now displays averages
4.many modules redesigned improved indicators using SVG no longer requires any jquery(no overheads)
5.Improved UV-Index indicators
6.Improved Rainfall Indicators with also last hour/yesterday values
7.Average Wind direction green indicator on compass
8.colored High / Lo  indicators on barometer
9.general clean up of unused code
10.selection of hardware to setup in easyweathersetup (if Davis selected displays Davis logo in footer)
11.sun position module based on azimuth also displays elevation
download size reduced to 4.1mb
« Last Edit: November 03, 2018, 06:53:23 AM by weather34 »
