Author Topic: VWS Alternatives or Addition to deal with WUnderground Issues  (Read 8072 times)
Offline waiukuweather
Re: VWS Alternatives or Addition to deal with WUnderground Issues
« Reply #25 on: March 02, 2017, 01:41:02 PM »
VVP can not handle LOOP2 commands
Offline 92merc
  • BismarckWeather.net
« Reply #26 on: March 02, 2017, 02:16:03 PM »
I followed some directions on disabling LOOP2 in CumulusMX.  My VP2 is older 1.8 firmware and can't do LOOP2 anyway.  That still didn't fix the issues when using MX and IP configuration.
But with LOOP2 disabled in MX and configuring MX to use COM1, it works just fine now.
Offline wbond
    • Chelsea Cove Weather
« Reply #27 on: March 02, 2017, 09:38:33 PM »
92merc, small world, I've been using VVP, Weatherlink, and VPlive in addition to VWS as well.  I set this up years ago and didn't recall why I setup VPlive, since I'm not doing anything with its data, although seeing your post makes me think it was probably to keep the console time up to date, had long forgotten about that, thanks.  Now running Weather Display in addition to all the above.  My VP2 is also on the 1.8 firmware.
Bill
Davis VP2+
Weatherlink Serial
VWS v14.00p86
DW3025
Offline SierraFoothills
    • Rail Road Flat Weather
« Reply #28 on: March 07, 2017, 05:36:39 PM »
Could you please tell me how you got the sky icon in the center of your "Current Conditions"?
I'm not happy with the solution I found.
mike
http://weather.railroadflat.org
Workarounds I have applied:
Forecast:  Weatherforyou 7 day sticker, easy Modification.
Mesonet:  redirects to WU mesonet and also joined Southwestern Weather Network, in the Scotts Valley CA station)
Alerts:  use RSS feed from feed wind and added php script for details From Saratoga Weather (Ken True has helped me-  needs PHP5.4+)
Bill
Offline ohlone
    • Weston Road Weather
« Reply #29 on: March 07, 2017, 07:12:04 PM »
I upload icon.jpg as part of the html file uploads every 5 mins.
You go into VWS Icon settings to have it generate the icon.jpg file.
I use Metar with Smart forecast override to get a reasonable Sky conditions.  I override the icon rain based on rain rate, etc.
Then I edited the USA.htx (which generated index.html) to reference icon.jpg instead of pointing to wundergrounds icon..
here is the snip:
<td bgcolor="#CCCCFF" height="19"><b><font face="Arial">Current Conditions
</font></b>
<font color="#808080" size="1" face="Arial">[Auto-updates every 5 minutes]
</font></td>
</tr>
<tr>
<td align="center" height="16">
<p align="center"><font size="2" face="Arial">Updated: <b>4:01pm on 3/7/17</b></font></p>
</td>
</tr>
<tr>
<p align="center"><font size="2" face="Arial">(<a href="http://www.mapquest.com/maps/map.adp?latlongtype=decimal&amp;latitude=37.0882797&amp;longitude=-122.0347366">location</a>)</font></td>
</tr>
<tr>
<td align="center" height="72">
<table border="1" cellspacing="0" bordercolor="#CCCCFF">
<tr>
<td rowspan="2" align="center" bgcolor="#53ff53"><b><font face="Arial">Currently:<br>
</font><font face="Arial" size="5">56.4°</font></b></td>
<td rowspan="2" align="center" bgcolor="#E1E1E1">
<p align="center"><font face="Arial"><b><img height="72" alt="Clear" src="icon.jpg" border="0"> <br>
</b></font></td>
Offline foxtrot722
« Reply #30 on: March 13, 2017, 08:30:40 PM »
Thanks for the tip, never had paid any attention to the icon feature, just modified my page.
<tr>
<td align="center" colspan="2">
<tr>
<td rowspan="2" align="center" bgcolor="#53d3ff"><b><font face="Arial">Currently:<br>
</font><font face="Arial" size="5">41.2&deg;</font></b></td>
<p align="center"><font face="Arial"><b><img height="99" alt="Clear" src="http://users.lowcountry.com/~yamaha3/icon.jpg"  border="0"> <br>
www.smoaksweather.com
« Last Edit: March 13, 2017, 08:34:42 PM by foxtrot722 »
Offline BrianLehan
    • Grace C Lehan Memorial Weather Station
« Reply #31 on: March 14, 2017, 02:17:45 PM »
I've looked at the popular replacements for VWS but I like the updates to other non WU sites VWS supports. Is there one out there that does them all as well?
Like most of you I have been making changes to the VWS template gathering data from other sources to fix the broken WU data. I've started loading seven day forecast from weatherforyou.com which I like and can live with. I have also replaced the broken local radar from WU with working live radar from WU. And I'm using a NOAA feed for the visible satellite feed. I also replaced the warnings with weatherforyou.com's but I can't find a warning text feed. Maybe RSS?
I'm still looking for solutions for mesonet and almanac data. I have a WU API key so in theory I could replace the missing WU items with API data but I'm unsure if I can add the data to the existing database in VWS or do I need to populate another database and reference that in the template? Anyone successfully using the free API to pull data and add it to existing VWS site?
Brian
Davis Vantage Pro 2 plus
VWS 15x on Windows 7
Sarasota-Weather Template
Gr3 Radar
Offline Jester
  • Pony Up!
  • US NAVY Retired
    • Castleton Weather, Virginia Beach, VA.
« Reply #32 on: March 14, 2017, 05:57:41 PM »
mike
Bill
Where did you get your template for your web site?
MADIS D4557
CWOP DW4557
Wunderground KVAVIRGI57
CoCoRaHS VA-VBC-13
Davis VP2+ 6163
WiFi LoggerV2
Offline ohlone
« Reply #33 on: March 14, 2017, 07:23:49 PM »
Original template started from Ambient VWS Website builder,  been hacking away at it over the years.
