Author Topic: NOAA WEATHER RADIO  (Read 103292 times)
Re: NOAA WEATHER RADIO
« Reply #825 on: April 06, 2018, 10:41:09 PM »
I don't have a background noise problem.  Instead, I got some degree of voice distortion.  Could this be my receiver at fault?  Transmitter?  https://stillwaterweather.com/wxradio
Also the 2nd home page using modified AltDashboard 6.95 at http://stillwaterweather.com/wx/2ndhome.php
Offline brandon86
« Reply #826 on: April 07, 2018, 12:33:09 AM »
Hey Doug, can a sdr like that be controlled by web?
So say if I, as a blind user was wanding to use that to stream a weather broadcast,  such as what I'm streaming now, with an sdr, is there a nonvisual way to do that?  I don't own a pie thus I'm stuck with 2 windows machins, well 3 really and a mac.
Just curious.
Brandon
Offline 92merc
  • BismarckWeather.net
« Reply #827 on: April 07, 2018, 11:14:33 AM »
For the broadcast, it doesn't use any webpages.  Only a command line like interface.  After initial setup, you use a program such as Putty to remote into it and run commands.
But after initial setup, there are few commands you'll need to run.  It just works for the most part.  About the only thing you might want to do from time to time is update the Jessie operating system.  But if you are behind a firewall, you don't really even need to do that if you didn't want to.
Davis VP2, Cumulus, WeatherDisplay, Blitzortung, Bloomsky, Saratoga Scripts, NOAA Stream via PI
Offline Cutty Sark Sailor
« Reply #828 on: April 07, 2018, 02:37:43 PM »
Bunty... check PM..
Cheers!!
Offline brandon86
« Reply #829 on: April 07, 2018, 04:44:00 PM »
I will listen to the Stillwater feed real quick and let you know what's going on.  The message will be sent after I check.
About the only thing I noticed is that it sounds like the station is a tad off frequency.
Not by much though, maybe .3 k off frequency so other than that it sounds quite alright to me.
Brandon, KC0USM
Check out http://bhsprn.tk:8000 for all the latest mountpoints streaming from their respective locations.
Offline brandon86
« Reply #830 on: April 07, 2018, 04:47:06 PM »
That's cool.
What's not cool is how cold it is in bismark right now.
BrandonThis by the way was in reply to the sdr discussion from the bismark end of things.
Brandon.
Offline 92merc
« Reply #831 on: April 07, 2018, 05:53:21 PM »
20 degrees below normal.  Expecting 6 inches of snow.  I was riding my motorcycle this time last year.
Offline brandon86
« Reply #832 on: April 07, 2018, 10:14:16 PM »
Hey that's ok it'll happen.  We'll talk about it and it'll change.
Offline lddaly
« Reply #833 on: April 08, 2018, 08:21:31 PM »
Friday we had our first round of severe weather since we started streaming KEC56 less than a month ago and it is already being discovered. It is always nice to get positive feedback from site visitors!
To: Webmaster
Randy
*@gmail.com
Message:
I found your website, and wanted to say thank you for hosting it.
I am happy to find a place where I can tune into KEC56 online.
Have a blessed day, and thank you again.
-Randy
Akismet Spam Check: passed
Sent from (ip address): x.x.x.x (x.myvzw.com)
Date/Time: April 7, 2018, 10:32 pm CDT
Coming from (referer): http://www.planoweather.com/wxcontact.php
Using (user agent): Mozilla/5.0 (Linux; Android 8.0.0; SM-G955U
Build/R16NW) AppleWebKit/537.36 (KHTML, like Gecko)
Chrome/65.0.3325.109 Mobile Safari/537.36
Offline brandon86
« Reply #834 on: April 09, 2018, 12:18:10 AM »
We're glad to see the feds up.  Let's hope we see more of the coming soon.
I wish to remind everyone my server is available for fulltime use now.
The details are,
bhsprn.tk
port 8000
password smokescreen
mount /callsign or /cityname
Thanks again.
Brandon
Offline chappelledpc
    • Stonybrook South
« Reply #835 on: April 09, 2018, 01:44:11 PM »
wxradio.dyndns.org Icecast server appears to have gone down about 12:10 PM CDT 04/09/2018
Will keep an eye on it.
Offline brandon86
« Reply #836 on: April 09, 2018, 02:34:23 PM »
Hopefully that server comes back up.
I'll look and let you know if it's back.
Brandon
Offline brandon86
« Reply #837 on: April 09, 2018, 02:37:21 PM »
Yes indeed, the server at http://wxradio.dyndns.org:8000 appears to be down from what I'm seeing.
Using IE it says, "Can't reach this page"
So Wonder if the icecast server is down for maintainence, updates or possibly having a problem.
And I was going to add KZZ52 to it's feed list too.
Well if nothing else, the bhsprn.tk server is running.
Or should be.
Thanks for the heads up.
Brandon
Offline 92merc
« Reply #838 on: April 09, 2018, 02:45:58 PM »
What's weird for me is all of my streams are down.  I didn't realize Crushed Box was down so I rebooted my PI.  After the reboot, my local stream and Broadcastify streams aren't working.  Not sure why one being down would stop the other three.
    • Stonybrook South
« Reply #839 on: April 09, 2018, 03:08:15 PM »
If you are using darkice, you may need to remove or comment out the section for wxradio.dyndns.org and restart darkice.
Offline NWROrg Team
  • Save A Life
    • NOAA All Hazards Weather Radio
« Reply #840 on: April 09, 2018, 03:13:44 PM »
The Cloud Provider for WxRadioDynDns.Org doing maintenance... Chris is checking, and may have to restart the server
3:10 PM
Offline 92merc
« Reply #841 on: April 09, 2018, 03:19:43 PM »
Looks like they are back up.  All 3 of my streams are active again.
Offline NWROrg Team
  • Save A Life
« Reply #842 on: April 09, 2018, 03:23:43 PM »
Yeo all back up ... Well Done Chris...
Some of you providers may have to restart your Encoders...depending on your settings locally.
Offline NWROrg Team
  • Save A Life
Announcing a New Feature: Audio Enhancements
« Reply #843 on: April 10, 2018, 07:53:08 PM »
Doug C and the Team are at it again!
Announcing the initial (BETA) release of the following:
(Click to access video demo)  Flash Shy? try this link... quality is not as good:
https://www.youtube.com/watch?v=8EcVLDIgQWA
Stay Tuned UU!
« Last Edit: April 11, 2018, 10:43:19 AM by NWROrg Team »
Offline brandon86
« Reply #844 on: April 11, 2018, 07:48:57 PM »
That actually sounds really, really good.
Keep that descriptiveness because for people who can't see or are totally blind, that's a big big thing.  They won't really need their screen reader to do much work other than to read the links and then Click the audio report thing and that'll take care of itself.
Offline NWROrg Team
  • Save A Life
Page Updates
« Reply #845 on: April 16, 2018, 08:35:13 PM »
Updating the HOW TO page
http://noaaweatherradio.org/howto.html
and would appreciate Proof checks, comments,...
Some of the material may be later moved to appropriate Quality and Reliabilty pages... maybe.
Changes include..
  • Addition of a secondary Icecast server, Courtesy of Brandon H
  • Experience and Refinement - corrections and Additionss - from first year online  :twisted:
  • Addition of an additional Encoder application that includes an Audio Processing Plug-In
         (rough draft tutorial at http://noaaweatherradio.org/Encoders/SECaster/sec.html )
  • Discontinuance of MOST third party Commercial Website served streams.
Save a Life!
Offline brandon86
« Reply #846 on: April 18, 2018, 01:29:01 AM »
Right on!
Amazing and I'm also going to examine this se caster app to see if it's accessible.  I'll write back over here to let you know.
I don't have another patch cable to tie into the mac to add a second stream of kz52 with the se cast pluggin on it.
However, speaking of kzz52, the stream should be much more stable than it had been.
Recently, Due to a few technical issues on my dell latitude d630 responsible for the initial stream test, I have moved my base of operation of that stream to my mac mini 2009 model.
Using nicecast, it is now streaming the NWR full time.
Let's keep up the good work team, you are all doing a finite job.
Brandon Hennis
Offline brandon86
« Reply #847 on: April 18, 2018, 01:40:32 AM »
It doesn't appear that the S E Caster, is working nicely with my screen reader, either that or I'm not sure how the input is supposed to look for how to connect it to servers.  It presents me with the following line of text, according to the screen reader.
Name/Address Srv Type Bitrate Listener Send Status
I don't know if it wants that all at once or what.
But, I shall learn for sure.
Maybe if I get it to wor I can see if I can get another radio to stream wxl62 from Sioux city, beings I can get that station also.
Pretty soon I'd better get me some more radios.
Brandon
Offline ComPilot
    • NOAA Weather Radio Stream
« Reply #848 on: April 21, 2018, 11:57:35 AM »
Hello All,
FYI - The Clearwater MN (WNG676) stream provided by Midwest Broadcast Engineering will be down from time-to-time today as we upgrade our internet service.
Have a great weekend!
Offline brandon86
« Reply #849 on: April 22, 2018, 01:44:55 AM »
Well if we could get Appleton Minnesota back, aberdine SD, Sioux falls, Hstings Nebraska, Kearny, Cheyenne Wyoming, I for some reason keep thinking there's still a lot more streams missing from the original wu setup, especially from California, we did have ridgecrest at one time, and Yosemite, so yeah, surprised we haven't heard from any of those providers.
Oddly once we started the audio feeds from Seattle they went down, so we don't have them either.
Brandon
Remember the icecast server, bhsprn.tk:8000
