Author Topic: GRlevel3 Publishing  (Read 1188 times)
Offline lperagallo
GRlevel3 Publishing
« on: February 05, 2017, 06:35:44 PM »
I have been using GRlevel3 for at least three years and it has been working fine.  I publish my files using the FTP build into the software.  I've attached a screen shot of the publishing panel.  I use Lonex as my host provider.  This should create 10 jpeg files with a name of KIND01, KIND02, etc.  My website shows the files as a loop.  Does anyone see anything wrong with this.  Is there a way to test this to see what error I may be getting?  This is driving me nuts.  It stopped working about a month ago.
Thanks for the help.  By the way the password is a dummy just to show how the statement is formatted.
ftp://lperagallo:louXXXX@www.lmk-enterprises.com/lmk-enterprises.com/weatherdata/
« Last Edit: February 05, 2017, 06:39:54 PM by lperagallo »
Offline Farmtalk
  • Fitzweather
    • Fitzweather
Re: GRlevel3 Publishing
« Reply #1 on: February 05, 2017, 06:40:56 PM »
Have you changed any settings recently that you are aware of?
Weather Software-> GREarth, GRAnalyst 2.xx, MRLevel3, GRLevel 3 2.xx, Bufkit, GRLevel2, WXSim, and Radarscope.
Weather Station-> Ambient Weather WS-1090 Fine Offset
Weather Station Software-> Weather Display 10.37S, Cumulus 1.94
CoCoRaHS ID->  WV-KN-27
Administrator-> www.fitzweather.org
Offline sacreyweather
  • Echo Valley Weather
« Reply #2 on: February 05, 2017, 07:10:42 PM »
What version of GR3 are you currently using?
Saline Weather on Twitter
Blitzortung Station 1387
Offline lperagallo
« Reply #3 on: February 05, 2017, 07:14:52 PM »
I haven't changed any settings.  that's what's so frustrating.  I also don't think my ISP changed anything.
I am running version 2.02
Offline lperagallo
« Reply #4 on: February 05, 2017, 08:10:42 PM »
What is the actual file name that is created.  Is it KIND01 or is it KIND_BR1_0.jpg?  I am using the site ID and sequencing it.
« Reply #5 on: February 05, 2017, 08:17:21 PM »
You need to update to the latest version, which is 2.52. There was a major change in the URL that the radar data comes from, among others.
Offline mkutche
    • GosportWx.com
« Reply #6 on: December 01, 2017, 08:52:01 AM »
I have godaddy and grlevel3 2.60 and it won't publish.. My ftp username is mkutche@gosportwx.com and I used the format ftp://mkutche:password@gosportwx.com/GR3
Says username is ok but the password is wrong when it is not..
Mike K.
WS2080 - Cumulus MX v3.0.0
Gosport, Indiana
Gosportwx.com Gosportwx.com/PWS/ Gosportwx.com/j-template/ twitter.com/GosportINWX facebook.com/GosportWxcom
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #7 on: December 01, 2017, 10:56:51 AM »
The username I use for my GoDaddy ftp is NOT the same username I have on GoDaddy!  They assigned me a username which I must use during ftp's.  Check for the correct ftp username.  Guaranteed it isn't 'mkuche'!
« Last Edit: December 01, 2017, 11:01:31 AM by gwwilk »
Regards, Jerry Wilkins
gwwilk@inebraska.com
« Reply #8 on: December 01, 2017, 10:58:36 AM »
I had a problem with GRLevel3 FTP Publishing. I found that the issue was a "special character" in my password. I had to use the "character encoding" in lieu of the special character.
If your password has any of the special characters, you might want to replace the character with the code.
I just rechecked my FTP setting on GRLevel3 and it has one of these. Here is a table (it includes my special character and code).
https://grox.net/utils/encoding.html
Offline mkutche
    • GosportWx.com
« Reply #9 on: December 01, 2017, 11:01:02 AM »
not sure what u mean i checked my ftp settings on grlevel3 and i have no special characters?
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #10 on: December 01, 2017, 11:03:56 AM »
Lets me connect fine using filezilla .. here are my ftp settings http://prntscr.com/hhs4ol
Mike K.
Gosport, Indiana
Offline gwwilk
« Reply #11 on: December 01, 2017, 11:09:40 AM »
Go to GoDaddy's 'Hosting Details' and check what your primary FTP User is.
« Last Edit: December 01, 2017, 11:11:48 AM by gwwilk »
Offline mkutche
    • GosportWx.com
« Reply #12 on: December 01, 2017, 11:12:07 AM »
not sure where that is
Mike K.
Gosport, Indiana
Offline gwwilk
« Reply #14 on: December 01, 2017, 11:13:50 AM »
They are characters like % $ # etc. If you don't have any, then this won't be your problem. I just thought that I would mention it because I ran into this.
Offline mkutche
    • GosportWx.com
Mike K.
Gosport, Indiana
Offline gwwilk
« Reply #16 on: December 01, 2017, 11:19:01 AM »
Try this: https://gateway.godaddy.com/ and then sign in and go from there.
Offline mkutche
    • GosportWx.com
« Reply #17 on: December 01, 2017, 11:21:40 AM »
turned out it was a special character see here.. http://www.wxforum.net/index.php?topic=33285.msg337415#msg337415
Mike K.
Gosport, Indiana
