Author Topic: Aercus Weathersleuth Professional IP Weatherstation  (Read 2038 times)
Offline Gil
« on: January 01, 2017, 05:35:54 PM »
Hello
I am new to this forum so please understand if I ask an old question.
I was given a Aercus Weathersleuth Professional IP Weatherstation for xmas. I was intending to use this on the APRS site as I am a Ham and would prefer to use their system.
This station plugs directly into my router with a lan connection. Can I route this to the aprs or do I have to use the Weather Underground site? If I can ca n
someone tell me the what I need to do to set it up or the ip address?
Regards
Gil
Offline waiukuweather
Re: Aercus Weathersleuth Professional IP Weatherstation
« Reply #1 on: January 01, 2017, 07:40:48 PM »
Hi
one solition might be
the weather display software does support the Wifi Pro station
and can be set to update to CWOP or direct to APRS (via TNC , either via the wxnow.txt file or a serial output)
there is a few steps to go through to get the data to the pc whe weather display would be running though (there is a link to those steps in the weather station type setup in the software)
Offline Gil
« Reply #2 on: January 01, 2017, 07:42:45 PM »
Ok thanks for that will check it out
Regards
