Author Topic: Error 500 - Internal server error  (Read 762 times)
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« on: December 06, 2016, 08:40:08 PM »
I just changed wifi routers and now Im getting this error trying to get to my site...
An internal server error has occured!
Please try again later.
I did notice to log into this router its 192.168.0.1 instead of the normal 192.168.1.1
Never seen this before... Any ideas?
Software: WeatherDisplay
Hardware: Davis VP2 + VP2 Solar + VP2 UV + Lightning Detector + Logitech Webcam
  • Mark
Re: Error 500 - Internal server error
« Reply #1 on: December 06, 2016, 08:49:56 PM »
I can get to my mobile page.. http://www.northbendweather.com/WWL-mobile.php
But not my main page... http://www.northbendweather.com
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #2 on: December 06, 2016, 08:52:44 PM »
This is the default error, it can mean practically anything - sort of "something is wrong".
You should see the details about the error in the error log.
If it is error in a script you could try changing the server settings and set the "display errors" option to ON, which would show you the line number and file name.
Alternatively, you could try it in PHP, but it does not always work, it depends if PHP can override the server setting.
ini_set('display_errors', '1');
error_reporting(E_ALL);
  • Mark
« Reply #3 on: December 06, 2016, 08:55:02 PM »
Where would I put that code?
Offline nincehelser
« Reply #4 on: December 06, 2016, 09:10:46 PM »
It sound like your new router might be based on 192.168.0.xxx instead of the original 192.168.1.xxx
Perhaps that has changed the IP number of some of the other systems on your network?
  • Mark
« Reply #5 on: December 06, 2016, 09:14:47 PM »
It was defaulted to 192.168.0.xxx , then I changed it to 192.168.1.xxx.
It strange that my mobile page loads, but not my main page.
Im not sure If I should change it back to the .0 or leave it at the .1
  • Mark
« Reply #6 on: December 06, 2016, 09:27:37 PM »
I think its fixed... Can a few people try my mobile page... http://www.northbendweather.com/WWL-mobile.php
and main page please... http://www.northbendweather.com/
Offline sacreyweather
  • Echo Valley Weather
« Reply #7 on: December 06, 2016, 09:32:07 PM »
Both worked for me, Mark.
Saline Weather on Twitter
Blitzortung Station 1387
  • Mark
« Reply #8 on: December 06, 2016, 09:36:19 PM »
Great... Thanks for checking. Its amazing how much you freak out when your page doesn't load...lol
« Reply #9 on: December 06, 2016, 09:41:32 PM »
Oh, definitely!!! That was like the first time I tried to use a .htaccess file and locked myself out of my own site. Nothing like feeling like an idiot when you have to open a trouble ticket to get back in.
  • Mark
« Reply #10 on: December 06, 2016, 09:57:37 PM »
lol... And most of the time its something minor that gets changed to cause your heart rate to go up.
